Old 12-09-2014, 02:03 PM   #1
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
Help me identify this wire! Extra wire around battery after clutch job
Hey all,
Can anyone tell me where this wire goes? I'm stumped... Could really use your help.
Maybe battery or starter? idk.
http://imgur.com/gyPWkQZ
YouShallKnow is offline   Reply With Quote
Old 12-09-2014, 02:32 PM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
That's a connection for ground. I think it's the one running through one of the starter bolts. I just did my clutch a few weeks ago and remember undoing it.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
YouShallKnow (12-09-2014)
Old 12-09-2014, 02:47 PM   #3
YouShallKnow
Drives: Man
Does your starter have three wires on it?
The instructions on the DIY Clutch thread indicate there's only 2, and if I removed this from the starter, I uncharacteristically left the nut on the bolt.
Maybe it goes to the negative terminal on the battery?
Old 12-09-2014, 03:03 PM   #4
zkv476
zkv476's Avatar
The starter itself has 2 wires, a positive cranking wire and a signal going to the solenoid. But the two long bolts that hold the starter to the trans/motor, one of them is bolted through that bracket you pictured. It's the ground for the starter and block in general.
Sorry for the slightly cruddy picture angle, it was rainy out and I tried jabbing my phone in that area. The starter bolt runs through the hole in the bracket.
Old 12-09-2014, 03:04 PM   #5
YouShallKnow
Drives: Man
I love you.
Wire Harness - simplify - extra gauges philooo Tracking / Autocross / HPDE / Drifting 0 11-30-2014 11:54 PM
Wire Harness SergeLo01 Scion FR-S / Toyota 86 GT86 General Forum 1 07-17-2014 08:06 PM
Wire Tuck DIM Cosmetic Modification (Interior/Exterior/Lighting) 20 08-11-2013 05:54 PM
Amplifier battery wire question!?!? mbh1101 Electronics | Audio | NAV | Infotainment 4 03-04-2013 10:07 AM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 11:22 AM
