Old 11-30-2014, 10:54 PM   #1
philooo
Drives: 13' Scion FRS Track car
Wire Harness - simplify - extra gauges
Ok so I see that company like precision chassis works are using Motec pdm30 on their car to control most electrical stuff inside the car, except engine. like wiper, horn ...
I am trying to understand what's the idea behind it? what are they able to remove by doing so ? can they remove all the wiring harness inside the cabin ? and just keep the poem wiring to the engine ? I have been trying to find info on that but no luck..
while looking at the motec website, I found a cool pdf document to their OEM harness replacement to the ECU for their advanced engine management. I don't plan on buying such thing but I see that they document the use of every single cable going to the ECU. Precious information I think. i see in there oil temp, oil pressure and even more cool stuff with the exact wire number... can we use that to tap into and wire some oil temp and pressure gauges ? sorry for the newbie question here I have no idea how the data is transmitted on these cables..
hoping to understand better what's the point of the motel pdm30 and is the poem wiring can be simplified and also tapped into for some oil gauges.
File Type: pdf CDS61264 Toyota86 M1 Loom Datasheet.pdf (1.54 MB, 194 views)
philooo is offline   Reply With Quote
Tweeter Wire Harness Lambo_FR-S Electronics | Audio | NAV | Infotainment 4 06-13-2018 09:08 PM
Wire Harness SergeLo01 Scion FR-S / Toyota 86 GT86 General Forum 1 07-17-2014 07:06 PM
MAF sensor wire harness SavingManuals Engine, Exhaust, Transmission 0 05-30-2014 08:20 AM
Photo request: FRS headlight wire harness Suffa Cosmetic Modification (Interior/Exterior/Lighting) 4 01-06-2014 07:48 PM
free wire harness on passenger side is for? SuperDave BRZ First-Gen (2012+) — General Topics 7 08-21-2012 01:12 PM
