Old 11-28-2014, 07:43 PM   #1
PNW FRS
PNW FRS's Avatar
Engine Ice Coolant
I've run Engine Ice in my water-cooled big-displacement motorcycle and had great results.
Anyone have experience -- or insights -- on using it as a replacement for the OEM coolant?
http://www.engineice.com/f-a-q.html
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 11-29-2014, 09:27 AM   #2
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
I wouldn't use it, but it is worth noting that there are other propylene glycol coolants in the world. For example: http://www.tractorsupply.com/en/stor...tifreeze-1-gal
Engine Ice's website isn't 100% factual. The most glaring falsity on there is that OEM's manufacture ethylene glycol. No OEM in North America manufactures coolant (they purchase it) and none are using glycol-based coolants anymore. They've all switched to OAT based coolants.
Hope that helps.
bimmer635csi is offline   Reply With Quote
Old 11-29-2014, 06:46 PM   #3
PNW FRS
PNW FRS's Avatar
Hope that helps.
Thanks. Quite a large price differential ($8/gal.) compared to "Ice."
2013 Asphalt / MT
Olympia, Washington
Old 11-29-2014, 10:58 PM   #4
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Here is another propylene glycol antifreeze:
AMSOIL Antifreeze and Engine Coolant
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 11-30-2014, 12:46 AM   #5
J_kennington
Drives: 2013 asphalt scion FRS
Haven't used it in a car. But it made a world of a difference on my yz250r.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 11-30-2014, 06:13 PM   #6
rx3
The most effective coolant would be pure water without any antifreeze (assuming temperatures don't fall below 0 C). As water has a higher heat capacity and a lower viscosity than propylene glycol or ethylene glycol: http://www.engineeringtoolbox.com/pr...col-d_363.html
rx3 is offline   Reply With Quote
Old 11-30-2014, 11:28 PM   #7
bimmer635csi
What does viscosity have to do with coolant properties? Water vapor has extremely low viscosity, but it is a horrible coolant.
Also, did you notice how the boiling point goes up as you have an increase in the percent propylene glycol in solution? This is a good point for a coolant system. It is known as a colligative property. Water vapor has an extremely poor heat capacity compared to a 50% solution of liquid water and glycol.
You may be thinking "race cars run water, so it must be better". This is because the tracks don't want to clean up the environment every time a car pops a radiator. If there is only water in the cooling system, there is no clean up required.
Old 12-01-2014, 04:15 AM   #8
rx3
I don't know what race cars run on - I'm just an engineer who presented a fact.
A lower viscosity cooling liquid will reduce pressure loss and less pressure loss leads to a higher flow rate = faster exchange of heat. And a lower viscosity cooling liquid has a more turbulent flow profile = faster exchange of heat.
Undoubtedly water is only a superior coolant in its liquid form (not as vapor). At least thanks to the fact that the cooling system is pressurized the boiling temperature is increased.
Engine Coolant system sw20kosh Engine, Exhaust, Transmission 1 04-01-2014 01:26 PM
Coolant low (when engine is hot) Ben_G Engine, Exhaust, Transmission 4 12-09-2013 09:31 AM
Green engine coolant used quickly? Tylub Issues | Warranty | Recalls / TSB 19 06-19-2013 02:15 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-14-2013 12:33 AM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 04:17 PM
