Old 05-04-2014, 12:48 PM   #1
Gunman
Drives: 2019 Mazda Miata RF
Ramps for low cars
Not a real step by step how-to, but I made a set of ramps for my BRZ, that you may want to try yourself.
For this set, I used 2 8ft long 2x10's, and angle cut the ends. The bottom board is extra long, because I plan to lower the car, and want to be able to get up on the first step, with the front fascia clearing the upper step. I have another set, that is just the top two steps.
The Following User Says Thank You to Gunman For This Useful Post:
amram (05-09-2014)
Old 05-05-2014, 12:35 AM   #2
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
I did the same thing for my dad's car a few years back. It works really well plus it's super cheap and easy to make! Did you put a small strip on the top(like a final backstop piece) to keep you from rolling off the back?
Husker BRZ is offline   Reply With Quote
Old 05-05-2014, 07:22 AM   #3
Gunman
No, but I do have the small wedge left from one of the miter cuts, that I may add...not sure it's enough though. It's definitely something I should have done in retrospect.
Husker BRZ (05-05-2014)
Old 05-29-2014, 10:10 AM   #4
Shedd22
BAMF
Shedd22's Avatar
Drives: 2014 SWP BRZ
I've been contemplating doing this to install an exhaust. Do you think theres enough room to slide under there and take the stock exhaust off and then fit a new one on?
Shedd22 is offline   Reply With Quote
Old 05-29-2014, 10:24 AM   #5
wlfpck
Drives: 2015 GTI
Haha nice!
I did the same thing. Couldn't use the rhino ramps that Autozone carries so I had to make some. Pretty much did the same thing you did except I did not do the angle cuts.
2013 GTI - Gone
2015 GTI
wlfpck is offline   Reply With Quote
Old 05-29-2014, 10:26 AM   #6
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Nice!
Love how the color of the stock rims look in your last pic. Wish the stock rims came with options as far as colors
Eurasianman is offline   Reply With Quote
Old 05-29-2014, 01:01 PM   #7
Gunman
Axle back for sure, cat back maybe. Depends on if you're lowered, and how skinny/claustrophobic you might be. You can always put one end up on ramps, and the other on jack stands, just be sure to block the wheels good.
Old 05-29-2014, 01:34 PM   #8
KDad2
KDad2's Avatar
Drives: 2013 Raven
I'm considering using these as ramps. I use them when leveling my camping trailer; which is 7500 lbs. [ame="http://www.amazon.com/Camco-44505-Leveling-Blocks-pack/dp/B00480BWCI/ref=pd_bxgy_auto_img_y"]Amazon.com: Camco 44505 Leveling Blocks - 10 pack: Automotive[/ame]
I haven't purchased these yet, but they also have wheel chocks that attach. [ame="http://www.amazon.com/Camco-44401-Leveling-Block-Wheel/dp/B007H2TF4Q/ref=pd_sbs_auto_5?ie=UTF8&refRID=1D3RABDE506A0TTCB 41R"]Amazon.com: Camco 44401 Leveling Block Wheel Chock - Pack of 2: Automotive[/ame]
KDad2 is offline   Reply With Quote
Old 05-29-2014, 09:49 PM   #9
ScorpionOzzy
Drives: Scion FR-S
Originally Posted by KDad2 View Post
I'm considering using these as ramps. I use them when leveling my camping trailer; which is 7500 lbs. Amazon.com: Camco 44505 Leveling Blocks - 10 pack: Automotive
I haven't purchased these yet, but they also have wheel chocks that attach. Amazon.com: Camco 44401 Leveling Block Wheel Chock - Pack of 2: Automotive
those are like big boy legos!
ScorpionOzzy is offline   Reply With Quote
Old 06-10-2014, 11:16 PM   #10
CatDaddysBBQ
Drives: '13 FR-S
I did an axle back swap with a setup like this, and I'm not small. I also utilized the slight downhill slope of my driveway, parking at the edge of the garage right before it went down. Easy.
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
Shedd22 (06-11-2014)
Old 06-11-2014, 03:57 AM   #11
dbrandt01
Drives: none
Haha, I've been wanting to build these. A lot cleaner than the one I threw together for an alignment. I plan on building a better one sooner or later though.
dbrandt01 is offline   Reply With Quote
The Following User Says Thank You to dbrandt01 For This Useful Post:
Gunman (06-11-2014)
Recommended Car Ramps for the BRZ/FRS? mechaghost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 09-01-2017 01:41 AM
Race Ramps offered at B2autodesigns: Free Shipping b2autodesigns Mechanical Maintenance and Tools 0 12-09-2013 11:00 AM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 05:43 PM
Low Race Ramps for Oil Change panman91 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 04-20-2013 03:28 PM
Free Shipping on ALL Race Ramps Products @ JWM JWMotoring Mechanical Maintenance and Tools 5 10-04-2012 06:22 PM
