Old 01-27-2014, 01:04 AM   #1
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Cool effects of elevation
As i understand it naturally aspirated engines lose approximately 3% per 1000 feet. So instead of ~170whp stock i am closer to 150whp at 4500 ft.
The question I have is does anyone know how this affects mods and tuning. Meaning will i get lets say 25hp from hks headers or will it also be dropped by that amount.
Will it be linear or will i get more/less at elevation than people at sea level.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 01-27-2014, 01:26 AM   #2
wheelhaus
wheelhaus's Avatar
An experienced tuner could answer this more accurately than I can. Since the air pressure is a measurement of available air density, the amount of air your engine can ingest is limited. The only way to overcome this limitation is via forced induction (turbo or supercharger). You need more air density to make more power, no matter the tune. So mod for mod, a car tuned at altitude will always make less power than a car at seal level because there's fewer air molecules to mix with the fuel.
The fuel contains the energy to make power, but it's ratio to the air molecules needs to be measured precisely. So, less air means less fuel, which ultimately means less power.
This is also why higher elevations may only see 91 octane gas instead of 93. We have fewer air molecules to compress, so less heat is generated before combustion, and there's inherently less risk of preignition (detonation, knock, ping) making lower octane safe.
Changing camber. Effects on toe? FReSh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-28-2014 01:51 AM
29 degrees F in Texas--near sea level elevation dave77 Scion FR-S / Toyota 86 GT86 General Forum 28 01-06-2014 01:57 PM
Boost gauge off at elevation gdrider77 Forced Induction 7 09-25-2013 02:32 PM
250 ~ 300 hp - Cost, Requirements, Effects Froylavin Engine, Exhaust, Transmission 14 07-19-2012 01:55 AM
effects of bigger wheels-video 315FR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 07-01-2012 10:50 AM
