BAMF
variable vane turbos
Why is it that no one has used variable vane turbos for our cars? I'd like t start a discussion on the pros and cons. I have a gt3782v that is currently a giant paperweight. I'm thinking that it would spool relatively early and could avoid excessive egt's with the size of the exhaust housing. What are your thoughts on something like this.
#2 |
Junior
Drives: a car
Use the search button. I already started a thread like this.
#3 |
BAMF
#4 |
Junior
Drives: a car
#5 |
Drives: 2012 WRX, 2003 RSX Type S
when people talk about variable vanes i think about turbine engines. the variable vanes in the t701d, uh-60 blackhawk engines, opens up to increase air and power. it is kept close until a certain power percentage is reach (NG). variable vanes in turbine engines change the angle on how the air is sent to the compressor, it uses the anti-ice start bleed valve to control the amount of air going into the compressor and diffuser. an actual design of such a turbo would make it pretty efficient but it would make the turbo pretty big.
| The Following User Says Thank You to blackhawkdown For This Useful Post: | thatfilipinoguy (07-30-2014) |
#6 | |
BAMF
#7 |
Junior
Drives: a car
To compress that kind of adjustabikity into a turbo of reasonable size, it gets incredibly complicated very fast. And its a direct coorilation to the price as well. If you already have one like the OP said, then id contact JDL as in the thread i posted they said they were willing to help with a custom setup if i ever wanted to make one.
#8 |
Drives: 2015 Series.Blue
Expensive and overcomplicated when a twin scroll with a quick spool valve would work nearly as good
Hell, even Honda knew that...
#9 |
Junior
Drives: a car
I never bothered to figure out what a quick spool valve is, care to enlighten me?
#10 |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
It's something you really see far more often on truck turbodiesels. I believe Ram trucks with the Cummins Turbodiesel have them as an option.
#11 |
#12 |
quick spool valves close off one "scroll" on a twin scroll turbo until a certain boost pressure is reached. This allows you have a very big turbo with a relatively quick onset of boost.
| Continuously Variable Transmission | Lexicon101 | Other Vehicles & General Automotive Discussions | 79 | 06-26-2015 04:18 AM |
| STi rear roof vane on BRZ? | Zechs21 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 10-13-2014 03:28 PM |
| Variable Gemoetry Turbo (VGT) | cdrazic93 | Forced Induction | 29 | 02-12-2014 12:12 PM |
| Dealership Accuses Variable Valve Timing (VVT) Ajustment | shiro | Issues | Warranty | Recalls / TSB | 48 | 12-20-2013 11:03 AM |
| Rotrak variable supercharger | madfast | Other Vehicles & General Automotive Discussions | 10 | 01-29-2012 12:14 AM |
