Old 05-17-2013, 11:19 PM   #1
Cal3000
Drives: Panda FR-S
Is engine knock normal for the FA20?
I logged some data while driving home. I have a tune. Apparently knock correction is occurring 5-8 time every 5 minutes while cruising. Is that normal? Doesn't seem good. I'm on 91 octane.
Cal3000 is offline   Reply With Quote
Old 05-17-2013, 11:44 PM   #2
Allch Chcar
Drives: N/A
According to the manual, some is normal on 91 octane. Serious knocking would be audible (with the windows down).
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 05-18-2013, 12:01 AM   #3
Cal3000
Drives: Panda FR-S
Audible would be knock corrections under -3 degrees if I remember.
Old 05-18-2013, 12:07 AM   #4
AVOturboworld
That's 91 octane for you.
Old 05-18-2013, 01:21 AM   #5
Cal3000
Drives: Panda FR-S
I'll probably put the stock map back on tomorrow and see how that looks. As long as there is no engine damage, I'm ok with a little knock
Old 05-18-2013, 01:18 PM   #6
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
why can't we have decent gas in this country???
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-18-2013, 05:55 PM   #7
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
My car seems to run well on the 93 we have here. Use to have 94 too, but I haven't seen that for a while.
Mobius357 is offline   Reply With Quote
Old 05-18-2013, 07:57 PM   #8
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Politicians.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 05-18-2013, 08:02 PM   #9
Visconti
Drives: 05 STi
Depends when it happens.. WOT old be a problem , but normal driving isn't such a big deal...these ecus have a advanced knock control system and normally can deal with this stuff pretty well
john
Visconti is offline   Reply With Quote
Old 05-18-2013, 09:08 PM   #10
Cal3000
Drives: Panda FR-S
john
Thanks for letting me know this.
I slapped back on the stock map and still knocking. ECU resets itself after flashing right? All these graphs are from Shell 91 octane.
The Following User Says Thank You to Cal3000 For This Useful Post:
Boofneenee (04-03-2014)
Old 05-19-2013, 12:32 PM   #11
arghx7
Drives: car
You'd be surprised how many new engines run like this. It's not just an FA20 thing. It's to maximize gas mileage and sense the octane level.
The Following User Says Thank You to arghx7 For This Useful Post:
Allch Chcar (05-19-2013)
Old 05-19-2013, 01:12 PM   #12
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
Yeah, I think it's the same reason the new direct injection high compression V6's in the new pony cars can run regular. Same with the Genesis 2.0T and I think the new Focus ST can run regular as well even though it's turboed.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 05-19-2013, 03:56 PM   #13
Allch Chcar
Drives: N/A
Premium unleaded is a tiny fraction of Gasoline use because it's significantly more expensive. Things have changed in the last 10 years, can you guess why?
http://www.eia.gov/todayinenergy/detail.cfm?id=11131
-Allch Chcar
Old 05-20-2013, 08:33 AM   #14
Dynotronics1
If it the calibration is set perfectly for your car and your fuel, then no they should be no KR. A 1.0 pull every once in a while on a 1 AM is fine, and will not cause any issues, but what your displaying looks like it needs a bit more work. I'm sure your tuner will finish it up, assuming you are sending logs
Dynotronics1 is offline   Reply With Quote
Engine Knock sound issue nos145 Issues | Warranty | Recalls / TSB 65 10-20-2019 05:57 PM
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 03:31 AM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 04:17 PM
anyone experience engine knock on 91 octane? chenshuo BRZ First-Gen (2012+) — General Topics 15 01-13-2013 08:10 PM
