Drives: 2015 Firestorm 08/05/15
Afr bung on overpipe
I will be doing my sprintex install soon and am going to run an afr gauge. I need to know if it matters to have the bung welded on the header after the secondary 02 sensor or can I have it welded on my overpipe. I have already had my header ceramic coated didn't want to have to redo it. I didn't know if that location close up toward the front of the over pipe and not on the header, would alter the afr numbers or not. Thx in advance. Steve
#2 |
Drives: 2014 BRZ
Do you have a cat in your header? If not, then you'll be fine to place it there.
#3 |
Drives: 2005 Toyota Camry
You can, but be warned that you will have virtually no access to it.
Much better to have it on the front end of the front pipe. -alex |
#4 |
Drives: 2014 FR-S
You could but that would be a tight fit. The best place for it is on the front pipe close to the over pipe.
#5 | |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Trust86 (03-28-2017) |
#6 | |
-alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Sportsguy83 (03-28-2017) |
#7 |
Yea I am running the Gruppe-s uel no cat header. Invidia overpipe, Berk highflow cat front pipe and the q300 cat back. I have the overpipe and header Cericoated. I was just looking down like you had said and it looked like I had room on the overpipe. But if it would still give me an accurate reading there is plenty of room on the front pipe before the cat. So to be clear as long as I installed it in front of the high flow cat on the front pipe I will be ok? and again thanks for all of your help and support I get from the forum. Thx Steve
#8 |
Alex, thanks partner, I just re read everything and you answered my question. I will put the bung on the front pipe just down from the collector but before the cat. thx Steve
#9 | |
That's what I'm planning on doing.
#10 |
I do. I am running the Berk High flow catted front pipe. I get it now Ultra, for it to read the mixture for the af meter it has to be after the cat. in my case since the one is not in the header it has to be the secondary. I think I have that correct. Hell I am confusing myself now (Ha) It doesn't take much anymore. thx partner
| The Following User Says Thank You to sroby For This Useful Post: | Ultramaroon (03-28-2017) |
#11 | |
#12 |
right on partner thx
| 02 bung in front pipe | ort895 | Engine, Exhaust, Transmission | 5 | 03-28-2016 01:23 AM |
| A/F Wideband O2 Sensor Bung Location | FyeaFRS | Engine, Exhaust, Transmission | 2 | 06-01-2015 10:17 AM |
| Fitting an additional O2 bung on Stock header? | dave- | Engine, Exhaust, Transmission | 6 | 02-19-2015 10:54 PM |
| HELP: O2 bung on Rev Works header stripped? | btoast | Engine, Exhaust, Transmission | 9 | 12-21-2014 07:11 AM |
| FS: AVO 2.5" Overpipe and Catless Front Pipe w/ o2 Bung | DesertFrs | Engine, Exhaust, Bolt-Ons | 0 | 04-01-2014 01:37 AM |
