Old 09-09-2014, 12:17 PM   #1
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
Talking Header and tune Decision
I'm running Invidia Q300 + invidia catless frontpipe + invidia overpipe, perrin inlet hose + perrin cold air intake + perrin crank pulley.
The sound is really good (pretty quiet) and the power also without a tune yet.
Now I'm looking for a Header + tune.
What do you people with experience in headers and tunes recommend? I've in mind until now this options in header:
JDL
Tomei
FT86SP Catted
And for the tune not sure if going with OFT or Ecutek.
I'm looking for the best power gains.
Thanks.
@Sportsguy83
Toyota GT 86 is offline
Old 09-09-2014, 12:21 PM   #2
FR-S Matt
JDL header in that list provides the most gains, lifetime warranty, and coating options. Superior to the ones listed.
Ecutek is better than OFT as long as you're having someone do a custom tune and not an off the shelf one. You can pull close or right at 200 whp with those mods and a JDL header on 93 octane. Depends on how good your tuner is and also not all cars being the same. With those mods though, 200 whp should be doable depending on what gas you have available.
FR-S Matt is offline
The Following 2 Users Say Thank You to FR-S Matt For This Useful Post:
Fast_Freddy (09-09-2014), Toyota GT 86 (09-09-2014)
Old 09-09-2014, 12:31 PM   #3
lucid215
im running the openflash headers and oft. havent got dynoed yet
lucid215 is offline
Old 09-09-2014, 12:34 PM   #4
DarkSunrise
DarkSunrise's Avatar
I've heard a few times now that OFT runs more timing (aggressive) to make the same power gains vs. what a tuner would do on a custom tune. Is anyone able to confirm?
2022 BRZ Build
2013 FR-S Build
DarkSunrise is offline
Old 09-09-2014, 12:52 PM   #5
FR-S Matt
I don't see how that's possible because not everyone's car is the same which is what OFT assumes.
A custom tune will ALWAYS be better because its tailored for your car and not everyone elses. You can maximize gains on the dyno and also keep your car in the safe operable range. When it comes to tuning, I wouldn't even think twice about the OFT because it's cheaper. I'm not saying you won't get gains from an OFT. It's just a matter of how your car responds to the file that everyone else uses and how aggressive the map really is. Ecutek even has off the shelf maps from tuners for people who want a quick solution. Ecutek offers so much more both N/A and FI down the road if that's the path you want to take. For FI, Ecutek is a must. Most professional tuners use Ecutek at shops on dynos for our cars.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Old 09-09-2014, 12:57 PM   #6
DarkSunrise
Sorry I may have been a bit vague as to what I was saying there. It was more a knock against OFT because I've heard it unnecessarily runs more timing than necessary for a given HP gain versus a custom (and theoretically safer) ECUTek tune. I was just hoping someone could confirm with hard data, as I haven't seen any yet.
So no one thinks I'm biased, I actually have an OFT on order that I'm thinking about canceling for a custom ECUTek tune. Still on the fence.
2022 BRZ Build
2013 FR-S Build
Old 09-09-2014, 01:01 PM   #7
FR-S Matt
I had a buddy remote tune my car on Ecutek and it runs amazing. All street pulls and I did probably about ~20 logs for him. Amazing what technology can do these days.
When I go FI, I'll be on the dyno though along with some street pulls. Not going to mess around with the tune for that.
Old 09-09-2014, 01:02 PM   #8
Shady195
Drives: '13 10 Series FRS #1203
You're comparing an OTS tune meant to be a happy medium on thousands of cars vs a more customized tune whether it be done locally on a dyno or as an etune..
A custom tune to YOUR car will always be better, and more expensive.
Shady195 is offline
Old 09-09-2014, 01:17 PM   #9
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Custom tuned, you will get the same exact result running OFT as you will any other platform (ecutek included). And I really don't believe there is more than a few hp left in our OTS tunes to be extracted from custom tuning.
Shiv@Openflash is offline
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
flippy (09-09-2014), Wayno (09-09-2014)
Old 09-09-2014, 01:18 PM   #10
Shiv@Openflash
Drives: 2013 FRS
Someone is feeding you nonsense, to put it bluntly.
Old 09-09-2014, 01:23 PM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
So, based on 2 (near) identical engines how does one make more power than another?
Also what is unnecessary ignition advance? Surely so long as it isn't knocking, why does it matter?
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
Old 09-09-2014, 01:26 PM   #12
DarkSunrise
Shiv,
Thanks I was hoping you'd chime in. If you don't mind me asking (I'm a tuning newb, so forgive my ignorance) but I've read that in broad strokes, the proper way to dial in timing is to advance it until you're not making any additional power on a dyno (and obviously not knocking), than dial it back 1-2 degrees from there for safety. Is that correct, and is that how you dialed-in the OFT maps?
Thanks!
2022 BRZ Build
2013 FR-S Build
Old 09-09-2014, 01:30 PM   #13
DarkSunrise
I assume through cam timing, A/F ratio, etc.
Unnecessary ignition advance would be any more than would make power on a dyno. Also see my post above to Shiv about pulling 1-2 degrees for safety.
Again I'm still learning about this, so I could be way off base.
2022 BRZ Build
2013 FR-S Build
Old 09-09-2014, 01:34 PM   #14
Shiv@Openflash
Drives: 2013 FRS
Shiv,
Thanks!
That's a sound approach if you can get to that point (Min timing for best torque). But on pump gas (and with high compression or turbo engines), you will run into detonation before that at most engine speeds. At which time the knock sensors will start to do their job and retard timing. So typically, one tunes up to this point on how much torque each advance increment is worth. At higher engine speeds, each degree can be worth big gains. So retarding 2 degrees from an ever-moving knock threshold isn't the best approach if you want something close to optimal performance. The mistake a lot of tuners make is that they dial things in exclusively on a dyno. And in a dyno room that doesn't have the best ventilation. So they are tuning in an environment that you will never see on the street. So once the car its the real world and breathes fresh air, it runs leaner than desired. Which is probably why they adopted the "retard 2 degree" rule. When the rule should really be "add a bit extra fuel"
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Wayno (09-09-2014)
OpenFlash-- header tune mtimney Forced Induction 3 08-07-2014 04:51 PM
Header + Android Torque -Tune major quicknap Software Tuning 4 04-29-2014 06:07 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
FI or Tune and Header? RSH Engine, Exhaust, Transmission 30 10-23-2013 06:09 PM
Should I buy my header or get a tune this week? Jtymay92 Engine, Exhaust, Transmission 27 06-20-2013 04:55 PM
