The Dictater
Drives: '13 Red Scion FRS
Overpipe Clearance to Frame
Hey folks. Installed a JDL overpipe on JDL headers and am getting the overpipe contacting the subframe frame issue with normal street driving. It sounds worse at AX lol. Already have the STI motor and transmission mounts installed.
Things I am planning to try: -I might be able to remount the OP a bit more to the left relative to the header given the slots clearance to the bolt. Piping would be a bit offset, but it's better than the racket on left hand turns. -Maybe there is a bit of wiggle room to kick the engine to the left a bit on its mounts? Loosen mounts and somehow shift engine. Would need to look if the mounts give any degrees of freedom for this. -Put a pad of some kind on the frame? Any more suggestions or advice?
Also: "Build Thread" |
| The Following User Says Thank You to Spuds For This Useful Post: | humfrz (04-08-2025) |
#2 | |
Drives: 2013 Subaru BRZ
I don't know how you would move the engine on the mounts though. It doesn't seem like there is that kind of flexibility in there. |
| The Following User Says Thank You to RT-BRZ For This Useful Post: | Spuds (04-02-2025) |
#3 |
Drives: 17 Asphalt 86
I'd get some pictures and contact Jesse at JDL. They must have made an error when fabricating it.
I had the same issue with my OP through local shop that made OPs for these. I'd be willing to bet it's touching on the passenger side of the subframe. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | Spuds (04-02-2025) |
#4 | |
The Dictater
I was thinking there might be a bit of wiggle room between the mounts and the frame. Might not need to do that though, was able to push the OP over a bit relative to the header.
| The Following User Says Thank You to Spuds For This Useful Post: | RT-BRZ (04-02-2025) |
#5 | |
The Dictater
You are correct. I'm adding pics below, I think my adjustment might solve the problem but I have a couple of other stuff to work on before testing.
#6 |
The Dictater
Loosened the OP to header connection and pushed the OP I bit to the left away from the frame. See pics below for before, after, and rub mark. Went from about 1/8 inch to 3/8 inch. I think this might work. Appreciate the suggestions!
#7 |
The Dictater
Just an update on my fix for anyone who comes across this later. Moving the OP over seems to have fixed the left turn issue. At least with the highest g I'm willing to pull on the street, haven't done an AX event on it yet.
However, now I have a strange clank sound when the right side of the car hits a specific kind of bump. I think it might be front pipe donut connector related since I had to move the FP over a bit when I moved the OP (since I didn't want to undo that connection too. That's a different problem though... Edit/update for anyone who comes across this. AX loads were fine, no more rubbing by the FP. Clanking was indeed donut connection, found a fix by shifting things around and using slightly different hardware. Seems like my JDL FP is not quite aligned with the bolt holes on my catback.
Also: "Build Thread" Last edited by Spuds; 10-29-2025 at 01:29 PM. |
#8 |
Drives: Crapcan
Has JDL said anything?
My setup is much different but still tight and haven’t had issues.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (04-11-2025) |
#9 | |
(why is this new generation making life soo hard for themselves?)
#10 |
The Dictater
I haven't asked them since the adjustment seems to have resolved that particular issue.
| Overpipe with sway bar clearance? | swift996 | Engine, Exhaust, Transmission | 40 | 07-05-2020 07:27 PM |
| BRZ / FR-S / GT86 Frame dimensions by E Frame v49 2013 | RWDfun | DIY (Do-It-Yourself) Guides | 3 | 02-27-2020 06:21 PM |
| Frame or no frame? | Missy | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 12-04-2013 12:47 AM |
| overpipe clearance | jamesm | Engine, Exhaust, Transmission | 12 | 11-16-2013 02:42 PM |
| Overpipe hitting frame/engine | Kregar | Engine, Exhaust, Transmission | 26 | 05-18-2013 11:23 PM |
