Old 05-02-2013, 12:48 PM   #1
Kregar
Kregar's Avatar
Drives: 2013 Scion FR-S, Asphalt
Overpipe hitting frame/engine
So I recently installed a Nameless front/overpipe and since have noticed a rattle under acceleration and turning left, this is similar to my last post but Ive narrowed it down to the over pipe hitting the frame or engine. There is less than a 1/4 of an inch between the bottom of the engine and the pipe, and if I push down on the pipe it hits the frame. So I am certian under load the pipe is shifting and hit one or both, Anyone have any idea for anything I can do to resolve this?
Kregar is offline   Reply With Quote
Old 05-02-2013, 12:56 PM   #2
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
High temp rubber bumper?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 05-02-2013, 01:05 PM   #3
Kregar
Kregar's Avatar
I am looking now I don't see anything I could really fit in there, maybe some high temp rubber tape?
Old 05-02-2013, 01:08 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Link?
Old 05-02-2013, 01:37 PM   #5
Adeets
OEDC
Adeets's Avatar
Originally Posted by Sportsguy83 View Post
Link?
Would have to know the diameter of the pipe, and how much room you have (from pipe to frame), and also how long you want the sleeve to be.
My BRZ FI Build
Old 05-02-2013, 01:42 PM   #6
Adeets
OEDC
Adeets's Avatar
If your pipe gets hotter then 350f then this won't work, you'd have to tàke the pipe off to wrap it.
Silicone rubber tape
My BRZ FI Build
Old 05-02-2013, 01:48 PM   #7
Sportsguy83
Drives: Limited BRZ
Pretty sure you can assume all exhaust pipe will get above 350, especially just after the header. I think probably a good thick amount of header wrap would be the way to go.
Old 05-02-2013, 01:51 PM   #8
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Stiffer engine and transmission mounts should reduce the movement.
JDKane527 is offline   Reply With Quote
Old 05-02-2013, 01:53 PM   #9
Adeets
OEDC
Adeets's Avatar
If ur pipe is between 450-350, I'd throw 3 wraps of this on it: glass tape then finish with the high temp silicone/rubber tape.
My BRZ FI Build
Old 05-02-2013, 01:56 PM   #10
Sportsguy83
Drives: Limited BRZ
One more suggestion before going the wrap route, loosen all exhaust components, insert a bar between the frame and the OP/DP. Now tighten all exhaust components and they should now bolt back up with the margin needed to not hit the frame.
Old 05-02-2013, 02:01 PM   #11
Adeets
OEDC
Adeets's Avatar
Silicone tape-450f
My BRZ FI Build
Old 05-02-2013, 02:03 PM   #12
Adeets
OEDC
Adeets's Avatar
Concerns me, because I to will be going the nameless up/down combo.
My BRZ FI Build
Old 05-02-2013, 02:07 PM   #13
Sportsguy83
Drives: Limited BRZ
This is not exclusive to Nameless. This does not happen to every car. The thing is that people do not post it on the forum. I know 3 people on 3 different OverPipes, 3 different brands hitting the frame but none wrote it on the forum.
I know over 10 people 3-4 different brands and their OP's do not hit.
That's the way it goes when modifying the car.
Ultimately, Nameless will take care of you, you can be 10000% sure of that.
Old 05-02-2013, 02:12 PM   #14
Adeets
OEDC
Adeets's Avatar
That's what they said about the borla UEL, I bought it... Warped flanges! With my luck (do note my car was sitting at a stop sign and I had a deer try to jump over it while I was stopped destroying my hood/roof. I was stopped, at a stop sign.) I'm gonna have the same issue he's having...
My BRZ FI Build
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
Delete driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 04-05-2013 12:43 AM
BRZs hitting Tampa, FL! FLHC BRZ First-Gen (2012+) — General Topics 63 07-24-2012 10:20 PM
First newspaper reviews hitting the web.... Sport-Tech BRZ First-Gen (2012+) — General Topics 12 05-12-2012 09:32 AM
Video: Ken Gushi Avoids Hitting Deer While Filming FR-S Commercial Jayvelliott FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 48 02-10-2012 01:41 AM
