Old 01-25-2023, 03:09 PM   #1
ihavefat
Drives: 2018 BRZ
Understanding the alignment specs
Recently got an alignment done and wanted to see if others could assist in helping me better understand the alignment results:
https://imgur.com/a/QHsgLDc
-How can you tell if the toe is IN or OUT? Wasn’t sure if “IN” represented inches or Toe In
-Is .01 basically 0 toe?
-Is .08 variance in camber significant delta ? I understand some shops will spend as long as possible to get the numbers dialed in exactly
-Do I need to be “concerned” about the caster spec? I’m just genuinely curious if this is something I really need to worry about in general.
Last edited by ihavefat; 01-25-2023 at 03:10 PM. Reason: Added the link to the picture
ihavefat is offline   Reply With Quote
Old 01-25-2023, 03:10 PM   #2
Racecomp Engineering
Do you have a printout?
- Andrew
Old 01-25-2023, 03:29 PM   #3
Code Monkey
Drives: Subaru BRZ
That's what you get not going to GTE.
Rear should be toe in so it looks like front is toe in as well. If the toe is out in the rear, you would discover it really quick going through a turn.
I would not worry about the variance in camber, too small to matter.
That caster is most likely cross caster, it is fine.
Code Monkey is offline   Reply With Quote
Old 01-25-2023, 04:13 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
https://en.wikipedia.org/wiki/Toe_(automotive)
+ = toe in
- = toe out
Alignment looks good assuming it wasn't super expensive, better then I'd expect from like a $60-$80 chain store, but if you got charged over say $120-$150 you might be getting ripped off.
That is assuming there aren't parts limitations and instructions that conflict - if you told them maximum camber up front and they did max it out - that's on you, less then a tenth of a degree difference in camber - you're fine. Depending on parts you have in the rear there may not be much to adjust to improve it, but again less then 0.1 degree is negligible in my experience.
ineedyourdiddly
Old 01-25-2023, 11:07 PM   #5
Decep
Drives: 2013 FR-S Series 10
You can't get an alignment anywhere for less than $150 these days from what i've seen. Alignment looks good! Bit of toe in for stability on the highway is never a bad thing.
0.08 degrees cross camber is NOTHING. Stock, these cars have sometimes ten times that... you're good!
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
Racecomp Engineering (01-26-2023)
Old 01-26-2023, 02:11 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Slight & even rear toe-in helps also with stability in lacking grip situations, eg. in winter on snow/ice.
Camber variance is no big issue, imho it should go to >0.5deg for butt dyno to feel differences in right vs left turns. But it's not so with toe, +/-0.1deg toe right to left can change handling noticeably.
Imho even less one can notice caster variances.
From overall camber amount, car suspension seems not 100% stock, i don't think one can get as high negative camber on stock suspension without camberbolts/camberplates. Rear also seems to have extra camber, maybe due LCAs, maybe due lowering.
Overall seems reasonable light-track/street hybrid alignment with less understeer (and less variances) then stock alignment. I'd wish 0 toe in front, and a touch more rear toe-in, but that's nitpicking.
Old 01-26-2023, 11:49 AM   #7
ihavefat
Drives: 2018 BRZ
- Andrew
Sorry, for some reason the image didn't upload initially so I had to add it after posting it. The link should be there now.
+ = toe in
- = toe out
Thanks everyone for the feedback! I wasn't sure how to interpret the spec sheet.
The Following User Says Thank You to ihavefat For This Useful Post:
Code Monkey (01-26-2023)
RS1 alignment specs DarkSideFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-08-2017 01:21 PM
1.0 trd springs alignment specs? Astroboy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-22-2015 10:54 PM
Alignment specs Thatguyjeremy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-06-2015 02:49 PM
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 07:30 PM
Alignment specs? russv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-03-2013 11:16 AM
