Drives: 2013 FRS
Driver side ball-joint nut loosening over time
Has anyone experienced the nut on the ball-joint backing off over time? It has the cotterpin so it doesn’t come completely off, but it’s backed off twice now (thankfully I check before a track day or road trip).
Also, every other car I’ve ever experienced had a castle nut/cotter pin on the ball joint. This car just has a regular flange nut and the cotter pin above it. The tie rod is a castle with pin, but I’ve seen pictures of other people installing ball joints and they have a regular flange nut like mine. What’s the definitive answer? I appreciate any input and advice. |
#2 |
Had my passenger side do this recently. The safety pin hole is a bit too high to prevent the nut from backing off so I put a washer between the nut and pin so there’s contact now.
| Coilover Ball Joint Bolt | scottryan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 07-30-2022 06:30 PM |
| ball joint leak | msaikhan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 05-01-2019 12:17 PM |
| Tie rod ball joint stuck | Killianti | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 07-19-2015 11:32 PM |
| Ball Joint Replacement, The fun way. | FRSPacNW | DIY (Do-It-Yourself) Guides | 2 | 06-28-2014 04:04 AM |
| loose ball joint | Grip Ronin | Issues | Warranty | Recalls / TSB | 15 | 07-09-2013 02:16 PM |
