| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2013 Scion FRS
Anyone feel like they have a clunky gear change?
I'm new to driving manual but I feel like I've gotten it down pretty well.
My only problem is that I feel my gear change is clunky. Even when fully stopped and my clutch is all the way in, changing gears isn't completely smooth. (no gas just clutch in and moving the shifter) I don't know if I just need a transmission fluid change or a new clutch. Does anyone else have this issue? |
#2 |
Panda Trueno
Drives: No twin now.
This is a known issue with multiple threads on it.
Generally people suggest swapping to motul 300 non LS. Otherwise do some research on google using "FRS gear clunk" or "Transmission shifting clunky, FRS" just some keywords like that and google search does wonders. |
#3 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following 2 Users Say Thank You to MisterSheep For This Useful Post: | go_a_way1 (03-28-2016), Summerwolf (03-28-2016) |
#4 |
These cars are a direct link from shifter to the gears and you feel the shift. Most modern cars (especially FWD) use a shit load of cables, rods and linkages and you simply do not feel the change since they take up all the movement.
They are not "bad", "broken" or in any other way inferior. All cars used to have this feel to them but guys that think of vehicles from the 90s as old school just have never experienced it. People say they like MT for the "feels" and then worry or complain when they actually feel something. You want smooth shift feels go buy something with a bunch of linkage and fool yourself that it is shifting "smoother". OK over to all those self proclaimed experts that have "drove MT for a full two years now" are going to explain to me why I am wrong.
| The Following 12 Users Say Thank You to Tcoat For This Useful Post: | FR-Slide (03-28-2016), humfrz (03-28-2016), jawn (03-28-2016), JohnJuan (03-29-2016), kevaughan (04-22-2022), MisterSheep (03-28-2016), roddy (03-28-2016), SuperTom (04-16-2022), Toyarzee (03-28-2016), Turdinator (02-11-2022), Ultramaroon (03-28-2016), Yoshoobaroo (04-16-2022) |
#5 | |
Killed Scion
| The Following User Says Thank You to MisterSheep For This Useful Post: | humfrz (03-28-2016) |
#6 |
Thanks
Isn't the smoothest and I cringe with a lot of my 2-3 shift but it hasnt blown up yet. High RPM shifts always seem smoother than daily driver shifts at ~3-4k RPM. Almost 40,000 miles with a decent amount of HPDE days on it. I run Motul gear 300 also
#7 | |
![]() I suggest you read @Tcoat s response carefully. Now, you aren't the only one who feels this way, so there is a good chance there isn't anything wrong with your transmission, nor are you doing anything "wrong". Several folks have changed the transmission oil and noticed a positive change. Also, keep in mind your transmission is relatively new, and will get smoother as it ages. You do know, a warm FR-S transmission is a happier transmission. Here is my prescription: I would suggest that when shifting, wind up the last gear pretty tight (4-5,000 rpms) (after the engine has warmed up) before shifting into the next higher gear. Also, when shifting, pull (or push) the shift lever slowly and firmly into the next gear. It's not a toggle switch ..... the lever is moving heavy transmission parts. I suggest you NOT "lazy leg" it ……. be sure to push the clutch pedal all the way to the floor. humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#8 | |
Drives: 2015 Lightning Red BRZ
sent from my phone using black magic |
| The Following User Says Thank You to zberz For This Useful Post: | MisterSheep (03-28-2016) |
#9 | |
I have looked into motul 300 but transmission fluid changes are so freaking expensive. Next paycheck hopefully! |
| The Following User Says Thank You to Haseebali31 For This Useful Post: | MisterSheep (03-28-2016) |
#10 | |
#11 | |
In other words, I have nothing to worry about?
| The Following 3 Users Say Thank You to Haseebali31 For This Useful Post: |
#12 |
Exactly! Just don't believe everything you read on here. each little foible of the car is not a huge issue. Many of the things are just the way it is.
#13 |
Drives: 2015 ISM BRZ Premium
Pretty easy to do yourself if you have a jack and stands (or a lift if you're fancy like that). DIY guides are available on here; just a search away.
#14 |
Drives: 2013 Pearl White 6MT
My 13 does it from time to time. Usually first and second. I wouldn't sweat it, because its a complaint of all manual twins. As Tcoat said, you will feel and hear everything even things you don't want to feel; in this car. Every snap clunk pop tick click clank crunk and crank, because the car is a sports car, and it has no lining under the interior panels, and you will soon find out its a beautiful thing to tuned into your car like that
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
| Change gear ratio? | Afdad120108 | Engine, Exhaust, Transmission | 61 | 08-17-2016 11:44 AM |
| Automatic Gear Ratio change | Toyota86.ir | Engine, Exhaust, Transmission | 31 | 05-10-2016 04:10 AM |
| Gear Ratio Change | Lunatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 06-26-2014 11:20 PM |
| This kind of explains how I feel in sixth gear | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 11-03-2013 01:52 PM |
| any way to change the gear ratios in manual? | SuperDave | Engine, Exhaust, Transmission | 17 | 10-19-2012 11:07 PM |
