Old 07-19-2013, 02:25 AM   #1
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Rear Deck Rattle? Fix it in 30s
I had a rear deck rattle. It was like a speaker rattling but was coming from the rear deck. If you pushed down on the rear deck on the side (passenger side for LHD, drivers side for RHD) of the rear window brake light it would stop.
Took car to the dealer and they did fix 1 and fix 2 on the Subaru TSB here http://www.ft86club.com/forums/showthread.php?t=21868 but no luck in fixing it.
Had a good investigation today following this thread from @jdubz http://www.ft86club.com/forums/showthread.php?t=14159 but removing the back lining looked too hard so I looked for an alternate solution and found one!
Here's how I fixed my rattle in 30s.
Open the boot (trunk for the USA) Look inside on the left (drivers side for LHD, passenger side for RHD). Just to the right of the boot (trunk) light under the rear deck you will see a bolt. A couple of inches to the rear of the car from that bolt you will see a small metal tax sticking out.
Bend that little tab slightly towards the bolt - I used my thumb but I suggest pliers, then you can pull the tab down while bending it in so that it holds down tightly the bit that is rattling.
Rattle gone! If it is still there but faint, bend the tab a little more.
Here's a pick of the bolt with the tab bent a little in. This photo is taken looking away from the boot (trunk) light.
There is another bolt with a similar metal tab by it on the other side of the boot/trunk (LHD passenger side, RHD driver side) but it is much thicker. I did push on that one too but don't think I bent it at all so don't think that one is an issue. but, if you still have issues you may want to look at bending that one ever so slightly.
I'm VERY happy my rattle is gone - hope it works for you.
As found by @XtremeMaC the tab holds down this sensor (likely keyless entry unit). With the tab loose this is what rattles. Seems that even if you don't have keyless entry this little unit is still sitting there.
nzer is offline   Reply With Quote
The Following 29 Users Say Thank You to nzer For This Useful Post:
10Stars (08-06-2015), 6speed_Sam (07-23-2013), Ayrton (12-21-2014), BRAWL (07-25-2013), charged86 (08-07-2013), Dadhawk (06-24-2015), Evil Jesus (09-17-2013), FRSBRZGT86FAN (07-19-2013), fstlane (09-04-2013), hanabie (09-17-2013), itdansharpe (07-19-2013), jcw99 (06-02-2017), KelvinBRZ (12-16-2013), Marrk (08-07-2013), neilvosko (12-04-2016), Outlander (08-07-2020), Pseud0logik (04-25-2014), Razzle (07-10-2015), sato (04-28-2016), Sc0ob_do0D (07-19-2013), Sigh-on-Rice (12-30-2014), Sportsguy83 (07-20-2013), tbwoodlee (07-25-2013), Tech (07-19-2013), tripjammer (09-03-2013), Wes (07-19-2013), ZeHeadBanger (10-22-2013), Zgrinch (08-08-2013), zoomzoomers (08-07-2013)
Old 07-19-2013, 08:00 AM   #2
colHolm
Default User Title
colHolm's Avatar
I'm going to try this today. Thanks!
colHolm is offline   Reply With Quote
The Following 2 Users Say Thank You to colHolm For This Useful Post:
bestwheelbase (07-29-2013), Flako (08-22-2013)
Old 07-19-2013, 11:19 AM   #3
frslee
Just drive it
Drives: 13' FR-S
stick foams in every gap you see!!!!
frslee is offline   Reply With Quote
The Following User Says Thank You to frslee For This Useful Post:
Flako (08-22-2013)
Old 07-19-2013, 03:46 PM   #4
nzer
nzer's Avatar
Didn't need to for my rattle. Just bending that little tab worked.
Old 07-19-2013, 04:17 PM   #5
Sc0ob_do0D
Sc0ob_do0D's Avatar
Drives: '13 WRB Lmtd 6MT
I never really encountered it before because I'm usually alone with music blasting. Now I hear it when the music is low and I'm actually trying to have a conversation with a passenger.
Thanks for this! Will definitely try it today.
Sc0ob_do0D is offline   Reply With Quote
Old 07-22-2013, 11:31 PM   #6
BlackyRose
Drives: 2013 Raven FR-S
What is the boot lol?
BlackyRose is offline   Reply With Quote
Old 07-23-2013, 08:22 AM   #7
Panman
Panman's Avatar
Drives: 86 GTS
What everyone outside the US calls the trunk
Panman is offline   Reply With Quote
The Following 3 Users Say Thank You to Panman For This Useful Post:
fuddbutter (07-25-2013), mixtape (06-21-2016), nzer (07-23-2013)
Old 07-23-2013, 02:38 PM   #8
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
nzer, that tab is exactly what's been rattling in mine since I did my exhaust months ago. I figured out what it was the other day and bent it slightly...all gone! You beat me to posting this!
I laid down in the trunk and started hitting the metal under the rear glass to find it.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
The Following 2 Users Say Thank You to 6speed_Sam For This Useful Post:
jcw99 (06-02-2017), mixtape (06-21-2016)
Old 07-23-2013, 03:43 PM   #9
nzer
nzer's Avatar
Thanks - edited to make it moe "international"!
Old 07-23-2013, 03:44 PM   #10
nzer
nzer's Avatar
LOL, that's what I did too. Amazing the noise it made right across the rear deck until bending the metal tab.
The Following User Says Thank You to nzer For This Useful Post:
jcw99 (06-02-2017)
Old 07-23-2013, 03:48 PM   #11
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I know! Something so simple was driving me crazy
The Following User Says Thank You to 6speed_Sam For This Useful Post:
Old 07-24-2013, 10:26 AM   #12
mwemy
Drives: toyota gt 86
the rear deck rattle your hearing is welding slag caught between both panels in the rear deck, only way to fix it is to spray some lithium grease in the gaps and hit the spotwelds back together... ive fixed numerous 86's this way and have never had one not fixed... about 20 and counting
mwemy is offline   Reply With Quote
Old 07-24-2013, 11:03 AM   #13
Jertronic
Jertronic's Avatar
Drives: FR-S 10 Series 120 of 2500
The last 2 times driving my brand new FR-S 10 a few loose, clunky noises have emerged out of nowhere. I haven't pin pointed the location yet, but it almost seems like the general area of the rear wheels or gasoline fill door.
I'll look at these tabs and bend them towards the bolts as suggested. I don't want to turn into a hypochondriac with this new ride. Only 300 miles on the odo.
Jertronic is offline   Reply With Quote
Old 07-24-2013, 11:41 AM   #14
vtmike
vtmike's Avatar
Drives: Scion FR-S
That's a fix for a different rattle.
Sent from my SCH-I535 using Tapatalk 4 Beta
vtmike is offline   Reply With Quote
The Following User Says Thank You to vtmike For This Useful Post:
jcw99 (06-02-2017)
Solution Found: Rear Deck Rattle jdubz Issues | Warranty | Recalls / TSB 29 10-13-2019 03:48 PM
Solution Found: Rear Deck Rattle jdubz DIY (Do-It-Yourself) Guides 31 08-23-2015 06:08 PM
eliminate rear deck popping with rear strut bar? chenshuo Issues | Warranty | Recalls / TSB 11 07-03-2013 07:44 PM
Wtb rear deck / headliner jshadeck Exterior Parts (Aero, Lighting, Etc.) 0 02-03-2013 09:31 PM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 05:35 PM
