Old 01-23-2021, 06:59 PM   #1
DoRebel
DoRebel's Avatar
Drives: FR-S 16”
Fuse box screws
Anyone know what part # these bolts are for the fuse box? Bought a used FRS 16, owned for a bit now and noticed these missing. Finally getting around to looking for it.
DoRebel is offline   Reply With Quote
Old 01-23-2021, 09:10 PM   #2
Ashikabi
Ashikabi's Avatar
Pretty sure it's a 6mm flange bolt. Fine thread
Sent from my ONEPLUS A5010 using Tapatalk
Old 01-23-2021, 09:57 PM   #3
DoRebel
DoRebel's Avatar
Drives: FR-S 16”
Thanks ! Will look for those.
Old 01-23-2021, 10:25 PM   #4
Ashikabi
Ashikabi's Avatar
A bolt with a washer would work ok too
Old 02-02-2021, 11:12 PM   #5
jflogerzi
jflogerzi's Avatar
https://parts.subaru.com/p/Subaru__B...1041CA000.html
2013 Series 10 FRS #553
Old 02-02-2021, 11:30 PM   #6
DoRebel
DoRebel's Avatar
Drives: FR-S 16”
Originally Posted by jflogerzi View Post
Thank you, this was the most detailed diagram I’ve seen regarding this + other bolts. Even when I was at the Toyota dealer we could not find a diagram that had the bolts.
The Following User Says Thank You to DoRebel For This Useful Post:
jflogerzi (02-04-2021)
Dashboard fuse box - mini fuse removal airrick Electronics | Audio | NAV | Infotainment 0 10-25-2019 06:05 PM
Oil leaking around oil pan screws James Russels Forced Induction 9 07-10-2019 08:51 PM
Rocketbuny Screws? Scalzo Cosmetic Modification (Interior/Exterior/Lighting) 12 02-22-2015 03:40 AM
Little black screws Cliu91 Issues | Warranty | Recalls / TSB 13 11-21-2014 04:37 AM
Screws. Chen Cosmetic Modification (Interior/Exterior/Lighting) 6 07-05-2014 10:14 PM
