Old 10-25-2019, 05:05 PM   #1
airrick
Drives: TRD R.S. 1.0 FRS
Dashboard fuse box - mini fuse removal
https://m.imgur.com/PtMgt9FHi,
Im at my witts end with this. My tail lights arent working but my brake lights are. I want to pull the fuses to see if its blown or not. But problem is, i cant even pull out the fuses. The tail light fuse in located in the fuse box under the dashboard. By hand, small needle nose pliers, even the special tool for fuse removal. Nothing. Im also certain i ruined the fuses in my attempts to remove it.
How can i remove this dang fuse out?
UPDATE: so theres a special tool thats in the fuse box in the engine bay. Its a white little plastic piece. you seriously need it to pull them out wihtout damaging these fuses.
airrick is offline   Reply With Quote
Fuse Help! KungFuWaffle Electronics | Audio | NAV | Infotainment 0 11-29-2017 02:41 AM
Best fuse to tap in? budul05 Electronics | Audio | NAV | Infotainment 2 07-12-2016 02:14 AM
WTB: OEM fuse box removal tool AG3NT_5CARFAC3 Want-To-Buy Requests 1 12-17-2015 03:14 AM
Best fuse to tap that is hot with car off? Frs32907 Electronics | Audio | NAV | Infotainment 0 08-30-2014 10:11 AM
Fuse Box beagoodruslan Electronics | Audio | NAV | Infotainment 0 04-19-2014 11:31 PM
