| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Subaru BRZ
Gas ethanol
Can a Subaru BRZ etc .. use 87 ethanol free gas . My state only carries that .
#2 |
Drives: 2015 FR-S
Add octane booster, then sure.
#3 |
Drives: Subaru BRZ
#4 |
[insert cool phrase here]
Drives: BRZ Premium
So.... your saying your too cheap to put 91 and want to save $2-3 for a tank full?
Yeah, you can but I'll drive like a grand ma so you won't get the engine knock.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#5 |
Drives: 2015 FR-S
No, I think he's saying the only ethanol free version is 87 octane. Probably has higher octane out of the pump available but not ethanol free.
to answer your question the car is recommended to have 93 or higher. Adding octane booster you can bump up the 87 to at least 93. Here: https://tinyurl.com/yxkyzfqy |
#6 |
The car is recommended to have 93 or higher but is required to have a minimum of 91. The car is also designed to run on up to 10% ethanol so there is zero advantage in getting ethanol free. It is not a 1954 Buick.
#7 |
TRACKBREAD
If anything get MORE ETHANOL!
Any modern car's fuel system can handle ethanol. Thousands of Subarus are running E85 without issues. |
| The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post: |
#10 |
The only reason to use non-e is to quiet the crickets down. Run the regular 91 or 93 and don't worry about them, don't run 87 except in a pinch.
#11 | |
I can only imagine how low the IAM would drop running 87 octane regularly.
2022 BRZ Build 2013 FR-S Build |
#12 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Zero reason to run 87. The crickets are not a problem if that is what you are trying to solve.
#14 |
| Ethanol or Non Ethanol | wolfer | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 03-25-2016 02:42 AM |
| Ethanol Vs Gas Cranking | Luckrider | Software Tuning | 2 | 01-25-2014 08:44 PM |
| Non ethanol gas | reesmicm | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 08-21-2013 02:14 PM |
| Ethanol | Andrew666 | AUSTRALIA | 30 | 08-09-2013 08:13 AM |
| 91 w/o Ethanol, or 93 with 10%? | Superhatch | Engine, Exhaust, Transmission | 21 | 05-20-2013 10:07 AM |
