Old 10-17-2013, 03:03 PM   #1
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Instrument Panel Fuse Box
Just a Head's Up:
If you ever have to replace a fuse at the fuse box located beneath the steering wheel - be prepared. You will need a flashlight or other light source and a very flexible body.
I used a portable "mini-pump" for tire pressure and blew the 15 amp fuse controlling one of the 12 volt power outlets.
Be sure to follow the directions for using the 'mini-pump'. I connected to the tire valve BEFORE turning on the pump.
BRZfan is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZfan For This Useful Post:
driftking96 (01-02-2017), humfrz (10-18-2013)
Old 10-18-2013, 12:32 AM   #2
Originally Posted by BRZfan View Post
Just a Head's Up:
If you ever have to replace a fuse at the fuse box located beneath the steering wheel - be prepared. You will need a flashlight or other light source and a very flexible body......
In addition, a mirror helps ....
extrashaky (07-10-2018)
Old 10-18-2013, 01:03 AM   #3
rishi
rishi's Avatar
Drives: FR-S Series 10 #0059
When I was messing higher up in the dash behind the fuse box (looking for a good spot to install a separate fuse box for aftermarket electronics), I found out that if you have a platform that's as high as your door step, you can lay on it and slide right under the fuse box quite comfortably - and if you don't, you're in for pain.
rishi is offline   Reply With Quote
The Following 2 Users Say Thank You to rishi For This Useful Post:
driftking96 (01-02-2017), jcw99 (06-01-2017)
Old 07-10-2018, 11:24 AM   #4
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
What are you guys using to remove the small blade fuses? The removal tool that came with my fuse kit is too big.
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Old 07-10-2018, 01:41 PM   #5
Find your SO's tweezers.
Just remember to put them back ….
FT86Z (07-10-2018), g e (07-11-2018)
Old 07-10-2018, 05:03 PM   #6
extrashaky
Drives: 2014 BRZ Limited
I remember wondering the first time I saw this topic come up why a mirror wasn't the obvious solution to everyone. I have also used my phone's front camera as an electronic "mirror" to display the fuse box on the screen underneath it.
Needle nose pliers. I'm sure there's some reason why you're not supposed to use them. But whatever that reason is, it's not good enough.
The Following 3 Users Say Thank You to extrashaky For This Useful Post:
FT86Z (07-10-2018), humfrz (07-10-2018), Outlander (03-17-2021)
Old 07-10-2018, 05:48 PM   #7
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
I swear I remember being able to use the puller tool that is in the engine bay fuse box
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
F/S: FR-S instrument cluster MissDeb Audio/Visual, Electronics, Infotainment, NAV 5 04-08-2014 05:02 PM
Is the instrument panel slightly angled (or just me?) 1Cor10:23 Scion FR-S / Toyota 86 GT86 General Forum 13 07-30-2013 07:04 PM
Subaru 85 pcs LED Instrument Panel Gauge JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 0 05-16-2013 10:22 AM
How to remove small instrument panel? boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 4 03-02-2013 05:07 PM
WTB: FRS instrument cluster jabbajaw99 Interior Parts (Incl. Lighting) 3 02-14-2013 02:31 PM
