Old 05-05-2017, 12:58 AM   #1
dman22
Drives: 2017 BRZ Limited
2017 BRZ iDatalink ADS-RR Headunit Install Compatibility
Hi guys,
I just wanted to know if anyone successfully installed the iDatalink ADS-RR Maestro along with the iDatalink HRN-RR-T01 harness with a Pioneer 4200 NEX. I bought these based on the recommendation of Crutchfied.com last week. At the time it showed that it was 100% compatible with the 2017 BRZ. I tried flashing the ADS-RR and now realize that is not the case as the 2017 BRZ is not even listed. I also went to the Crutchfield website and they now have nothing recommended for the 2017 BRZ. I bought the parts from different vendors, so am I SOL or is there a way to make it work somehow on a 2017 BRZ? Thank you for any information in advanced guys.
dman22 is offline   Reply With Quote
Old 05-05-2017, 11:53 AM   #2
Chimera
Drives: FRS
try the 2016?
I personally haven't messed with the idata link before, I just have a 4100nex and a Bluetooth odb2 that I use with torque. what features are you trying to retain, or gain with the datalink? steering wheel controls, tire pressure readouts? i'm just curious mostly. IIRC the 4200 and 4100 are the same with the exception of the data link support, and I think the 4200 got a faster processor... which the 4100 needed if im being frank.
Old 07-05-2017, 05:43 PM   #3
007BRZ
007BRZ's Avatar
Drives: 2017 BRZ Yellow Spec Ed 1of500
I just had installed the iDatalink ADS-RR Maestro along with the iDatalink HRN-RR-T01 harness in my 2017 Yellow with a Kenwood DNX893S. The tech that installed it is a master Kenwood installer with the same unit in his Toyota. It was a major pain in the butt. Everything is working, Sirius, Backup camera, Garmin Nav, BUT only the "Source" steering wheel button works on the idatalink, waiting for them to release an updated flash. Sort of pissed that I have to pull the unit out to reflash it later on.
007BRZ is offline   Reply With Quote
The Following User Says Thank You to 007BRZ For This Useful Post:
Chimera (07-05-2017)
Old 07-11-2017, 10:59 AM   #4
007BRZ
007BRZ's Avatar
YES. MY KENWOOD DNS893S is installed New idatalink flash is ready
Originally Posted by dman22 View Post
Hi guys,
I have EVERYTHING WORKING NOW. IDATALINK NEW FLASH IS NOW ON THEIR SITE. YOU SHOULD TALK TO THEIR SUPPORT. YOU WILL SEE YOUr STEERING wheel too
See my other posts and pictures
Old 02-20-2018, 02:48 PM   #5
djezlee
Did you have to splice any wires.... or is it all plug and play?
djezlee is offline   Reply With Quote
Old 02-21-2018, 09:44 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Crutchfield is so far off with ANYTHING 2017+ on this platform. I had a chat trying to figure out what I needed and decided to go elsewhere, the guy insisted I needed a 1DIN unit...
I'm not doing the iDatalink though, need my OBD port.
Old 02-22-2018, 10:58 AM   #7
Blue Gumby
Drives: 2017 86
I agree Crutchfield can sometimes be off. When I got my Kenwood HU for my 2017 86, the install instruction and ready harness was for 2013 FRS. Had to figure out how to wire the oem camera by myself. I did get the iDatalink for it, very happy with it. I did get a OBD2 splitter from Amazon so I can use the other OBD2 port
Blue Gumby is offline   Reply With Quote
Old 03-13-2018, 08:04 PM   #8
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
You don't have to use the OBD port, there are CAN bus leads on one of the stock radio harnesses.
Originally Posted by Admiral Ballsy View Post
It's listed in the schematics as "option connector", D29. The pink and blue wires are CAN bus, orange is B+ (fused through the dome lamp fuse), black/yellow is ground, red/black is accessory power (radio fuse).
From thread
Some more information can be found here.
mrderp is offline   Reply With Quote
The Following User Says Thank You to mrderp For This Useful Post:
cjd (03-13-2018)
Official 2017 MY CHANGES (Full Document) and Backwards Compatibility Discussion Stang70Fastback BRZ First-Gen (2012+) — General Topics 301 06-08-2018 03:07 AM
2017 BRZ Headunit (and Dash!) Replacement Dok Henz Electronics | Audio | NAV | Infotainment 105 04-14-2018 01:23 AM
Subwoofer Install for dummies (Stock Headunit) Matty-T DIY (Do-It-Yourself) Guides 2 07-27-2015 04:14 AM
List (you contribute) Phone Bluetooth Compatibility BRZ stock headunit robot Electronics | Audio | NAV | Infotainment 15 01-09-2014 02:44 PM
oem headunit install encity5 Electronics | Audio | NAV | Infotainment 4 07-22-2012 11:27 PM
