Old 04-10-2014, 02:20 AM   #1
Pokeguyjai
Pokeguyjai's Avatar
Drives: 2013 GBS BRZ (AT)
Greddy Oil Drain Plug - Leaking
Hi guys,
I installed a Greddy oil drain plug in my car. It did not have any leaks after I did my first oil change (obviously when I swapped it in). But after the second oil change (new crush washer) it started leaking. I torqued it down to factory specs. I just did my fourth oil change a few hours ago and just saw a small pool of oil under the car. Not huge, probably a few good sized drops. Going to go back to the OEM drain plug when I do another oil change in a few weeks after a track day just to stop the leaking.
Was wondering if anybody also had the same issue?
Pokeguyjai is offline   Reply With Quote
Old 04-10-2014, 02:48 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Not common but for future to note a quick valve by "Fumoto" is quick. Once on it's there for life and so clean and simple to do oil changes with. If it's the magnetic attraction there are filter mags and also filters like PMU and HKS that have magnetized filters to.
The Following User Says Thank You to OICU812 For This Useful Post:
Pokeguyjai (04-10-2014)
Old 04-10-2014, 03:15 AM   #3
retrosmiths
Drives: Scion FR-S Whiteout
^ Fumoto, not fumitory.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-10-2014, 03:16 AM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Was the factory Subaru washer glued/painted to the oil pan?
-alex
Old 04-10-2014, 04:05 AM   #5
OICU812
Just a dude
OICU812's Avatar
Yes iPhone auto correct sorry "Fumoto" is what I meant to have displayed.
Old 04-10-2014, 05:44 AM   #6
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I want Fumoto, I want magnets to catch bits and I want Hachi Roku OEM Oil filter... Decisions decisions...
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 04-10-2014, 09:17 AM   #7
Pokeguyjai
Pokeguyjai's Avatar
-alex
Negative.
BTW does anyone know if I can reuse my engine oil if I swap out the plug? It is literally brand new, just put the fresh engine oil in yesterday.
I really want to stop this leak.
Old 04-10-2014, 10:21 AM   #8
sshole
Why wouldn't you be able to reuse it? Just make sure you catch all your used-new oil in a clean(ish) pan.
sshole is offline   Reply With Quote
Old 04-10-2014, 12:47 PM   #9
mav1178
mav1178's Avatar
Get the filter you want.
Get Fumoto.
Get Filtermag.
-alex
Old 04-10-2014, 03:32 PM   #10
mashal
DADA
mashal's Avatar
Drives: 2013
The greddy one comes with a washer .. So washer and then crush washer.
That's why your leaking
mashal is offline   Reply With Quote
The Following 2 Users Say Thank You to mashal For This Useful Post:
mav1178 (04-10-2014), Tim_Asphalt_FRS (04-15-2014)
Old 04-10-2014, 03:41 PM   #11
Simon99
Simon99's Avatar
Get Fumoto.
Get Filtermag.
-alex
Love you
Sent from my SGH-I337M using Tapatalk
The Following User Says Thank You to Simon99 For This Useful Post:
Old 04-10-2014, 03:45 PM   #12
mav1178
mav1178's Avatar
Solution right here... it's either 1x crush washer, or 1x normal washer. Not both!
-alex
Old 04-15-2014, 02:55 PM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
-alex
I was thinking about same thing.
I use Greddy plug too but i havent changed my oil for 2nd time yet.
Old 04-15-2014, 03:13 PM   #14
wheelhaus
wheelhaus's Avatar
I also highly recommend the Fumoto valve. Just raise the front of the car high enough to reach the plug and slide a low profile drain pan under there.
It makes oil changes are so easy on this car it gives me wet tip.
The Following User Says Thank You to wheelhaus For This Useful Post:
JB86'd (09-16-2015)
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 11:59 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 07:04 PM
GReddy Magnetic Drain Plug BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 01-05-2013 11:19 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 12:28 PM
