Old 06-14-2016, 10:41 PM   #1
xFury
xFury's Avatar
Drives: '16 Scion FR-S - Oceanic
Wiring dash cam for rear window
Hey everyone, I'm planning to get another dash cam to hook up to the rear window, how would I go about wiring it?
Currently the front window dash cam is plugged into my cig lighter and comes on when I go to acc switch, how would I make it function the same?
Thanks!
xFury is offline   Reply With Quote
Old 06-14-2016, 11:03 PM   #2
ryoma
ryoma's Avatar
if you want a simple solution, get a dual USB charger and put it in your glovebox. run both dashcams to that charger and hide the lines. you will need to run your rear wires through the head liner.
Old 06-15-2016, 04:33 AM   #3
adtsoft
Drives: 2016 Scion FR-S
Pop off the trim above the glove box and wire from there. There is lots of room behind that panel, it is where I stashed a Sirius receiver with plenty of room to spare.
adtsoft is offline   Reply With Quote
Old 06-15-2016, 04:14 PM   #4
ryoma
ryoma's Avatar
I ran my dashcam through the headliner to the passenger A pillar and down the door sill partially (tucked wire behind the rubber strip) then through the side of the glovebox. there is a panel on the side of the glovebox that pops right off and it has a hole that leads into the glovebox. the panel goes back on without clipping any wires. easy job, though getting the A pillar trim back on was kind of a pain until I figured out there was a hidden clip
Old 06-16-2016, 06:00 AM   #5
tracerit
Drives: '13 SSM BRZ Limited 6MT
Is there an airbag behind the front A pillars and rear C pillars? I'm thinking about running wires through them to hide both dashcam and rear high mount brake light but concerned about compromising the safety of the passengers (well just the front since no one can fit in the back lol).
tracerit is offline   Reply With Quote
Old 06-16-2016, 03:45 PM   #6
ryoma
ryoma's Avatar
there's an airbag behind the A pillar for sure, not too sure about the C pillar but I would assume there to be one too since it's pretty close to a person's head if they sit in the back. with the force that an airbag has when deployed, I doubt a few wires will hold it back. if anything, it will rip the wires out and possibly your dashcam too when it deploys lol.
Old 06-16-2016, 05:10 PM   #7
FX86
i didn't even bother hiding the cables to my rear dash cam..it's not like i have passengers in the rear so i just threw the wire into the back seats
Old 06-18-2016, 07:40 PM   #8
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
I have a blackvue + magic pro.
I ran the rear from the glove blox. Get a splitter for the lighter output.
Pop open the trim on the passenger side, and route it up the passenger front pillar through the rear, and it all tucked within the rear head liner.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Dash Cam Hard Wiring Alternative steeloyangster Scion FR-S / Toyota 86 GT86 General Forum 24 02-02-2016 03:20 PM
Unknow wiring under dash kamilgt BRZ First-Gen (2012+) — General Topics 2 01-15-2015 09:01 AM
Full Dash including wiring C130NAV Want-To-Buy Requests 7 11-06-2014 11:57 AM
Rear fog wiring Gunman DIY (Do-It-Yourself) Guides 0 02-17-2014 09:26 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 03:23 PM
