Old 02-17-2014, 08:26 PM   #1
Gunman
Drives: 2019 Mazda Miata RF
Rear fog wiring
Not really a guide, looking for input.
Currently I have my rear fog wired to the tail lights. I was thinking I'd like to have it on when the DRL's are on, as a sort of rear drl, for those times when it's not dark enough for the headlights to turn on, but I'd still rather not get rear ended. So, I was thinking of using the turn-on lead for the amp.
In this case, the rear fog would be on, whenever the car is on, unless the radio is off? is the amp turn-on controlled by ignition, or radio? too much draw for the turn-on lead? I could use a relay if need be too, and tap into the amps power lead too.
Any other sources of power in the back of the car?
Gunman is offline   Reply With Quote
How to use the OEM amp Wiring RandomHero Electronics | Audio | NAV | Infotainment 258 07-04-2024 12:34 PM
Valenti rear fog alternate wiring Gundark Cosmetic Modification (Interior/Exterior/Lighting) 87 09-14-2016 03:12 PM
Wiring BRZ rear fog light to only come on with front fogs Scenic Driver DIY (Do-It-Yourself) Guides 4 09-12-2015 09:36 AM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
HELP WIRING MY ZETA REAR BUMPER BACKUP LIGHT DealerFR-S Cosmetic Modification (Interior/Exterior/Lighting) 2 08-09-2013 05:55 AM
