Old 06-09-2016, 11:14 PM   #1
swarb
Wheel bearings sealed? Grease?
Are our wheel bearings sealed? If not, what type of grease do they use? Repack with another type?
Old 06-10-2016, 09:32 AM   #2
OkieSnuffBox
Drives: '23 BRZ Limited
1. Yes.
2. Whatever cheap junk they can find. And usually lightly packed.
3. I would, especially if using for Auto-X/Track.
Even though front hubs don't seem to be an issue on these cars, on NA/NB Miatas it was a huge problem. To the point that there 4+ vendors offering upgraded hubs.
Some were just stock hubs that had been repacked with high quality grease (withstand high temps better).
Some were rebuilt with higher quality grease and ARP studs.
The most high end ones went so far as to change out the ball bearings for one closer in tolerance (more even loading on all the bearings), plus high quality grease and ARP studs.
I wish there were some options like this for us, I hate doing jobs like that.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
swarb (06-10-2016)
Old 06-10-2016, 11:08 AM   #3
stevesnj
stevesnj's Avatar
Originally Posted by OkieSnuffBox View Post
1. Yes.
Typically front bearings are quite durable and aftermarket are the junk ones. I had an original front bearings last 200k miles in a car.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
swarb (06-10-2016)
[HELP] Rear Wheel Bearings VITA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 10-14-2019 02:58 AM
Oem rear wheel bearings+oem inner tie rods Integramike94 Brakes, Suspension, Chassis 7 09-25-2016 06:48 PM
Grease gun tips? ZionsWrath Other Vehicles & General Automotive Discussions 3 12-07-2015 09:29 AM
True to add grease to the wheel lock nuts or not necessary? dssence Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-05-2014 01:27 AM
Are our wheel bearings and bushings sealed or are we able to grease them up ? ScionFR-S Issues | Warranty | Recalls / TSB 4 01-28-2014 09:49 PM
