Drives: scion frs
Right low beam not working.
Ok so yesterday my hid right low beam went out, so i try to put the oem bulb there but it wont turn on. Also I switched the ballast of the left side to the right and nothing. Does anyone know what the issue might be ? Thanks.
Sorry if this is a double post. Sent from my iPhone using Tapatalk |
#2 |
Can't remember off the top of my head but I believe the underhood fuse box has seperate fuses for driver and passenger side headlights. When the bulb/ballast went it may have popped the fuse.
| The Following User Says Thank You to Boostedpro For This Useful Post: | zman (04-24-2015) |
#3 |
Drives: scion frs
Ok thanks ill try that when I get a chance
#4 | |
Drives: scion frs
Also do you know what the fuse is marked as? Sent from my iPhone using Tapatalk |
#5 |
It is labeled as "H-LP RH LO" it should be a 15amp fuse according to the wiring diagram. Don't know for sure if that is how it is labeled on the fusebox though.
#6 |
Because Racecar
Drives: 2014 Scion FR-S
Wow this exact thing happened to me a week or so ago. Mine ended up being a blown fuse. It's a blue 15amp for sure. There's a replacement extra already in the fuse box. The back of the fuse cover will show you where it is.
| The Following User Says Thank You to kchar For This Useful Post: | Tan (03-14-2016) |
#7 |
Drives: scion frs
Ok thanks guys 😀 im glad it's just a fuse because I was about to take it to my dealer lol.
#8 |
Drives: scion frs
All fixed 😊
#9 | ||
Drives: Asphalt frs
Any pics of the fuse think I just blew mine also do we get replacement fuses if so where ?
Sent from my SM-G935T using Tapatalk |
#10 | |
Drives: scion frs
We do get replacements, I will try to get a picture tomorrow but it says it on the box where it's located Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to zman For This Useful Post: | SoCal80six (03-14-2016) |
#11 |
Drives: Asphalt frs
#12 |
Drives: 10 Series #974 6m/t
Why would only one side pop a fuse ?
#13 |
Drives: scion frs
| Crash Beam | afishl1 | Exterior Parts (Aero, Lighting, Etc.) | 1 | 04-12-2015 12:51 PM |
| Hi beam indicator | Norkoastal | BRZ First-Gen (2012+) — General Topics | 4 | 12-10-2013 12:53 PM |
| DRL or high beam or both? | jacobzking | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 06-09-2013 03:09 PM |
| HID and high beam use | gatorbushmen | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 04-19-2013 04:56 PM |
| Low beam on indicator? | percyng | CANADA | 5 | 10-10-2012 04:47 PM |
