Old 02-13-2016, 03:44 PM   #1
Estey
Drives: Scion FR-S, Ultramarine
Bad Strut Mount Bearing
So, Ive had this clunking sounds coming from the front of my car for a while now. I just got around to checking out my steering rack this morning, but I eventually tracked the sound down to my strut when turning the wheel.
Im assuming this is due to a bad strut mount bearing. Im on Buddy club racing specs, and Im not sure what action to take next
Will I have to buy new top hats specifically for my coilovers, or maybe replace the ball joints?
Estey is offline   Reply With Quote
Old 02-13-2016, 04:11 PM   #2
Cole
Not a troll
Cole's Avatar
You'd probably be able to get new bearings. Did you contact BC to see what they recommend?
Cole is offline   Reply With Quote
Old 02-13-2016, 04:14 PM   #3
Estey
no I havent yet, but Ill do that today and update the thread with their response.
Old 02-15-2016, 04:34 PM   #4
Estey
Can anyone else provide input? No word from bc yet
Old 02-21-2016, 09:40 PM   #5
Estey
Buddyclub asked me for some photos for their techs to look at a week ago, and they have still not gotten back to me... I sent a follow up email a few days ago as well.
does anyone know what to replace if it is a bad strut mount bearing?
Old 02-21-2016, 10:10 PM   #6
Teseo
Drives: frs
Complete top hat
Old 02-21-2016, 11:01 PM   #7
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
If you've got the time and capability you might be able to remove the bearing from the strut mount and find a replacement for it. I can't imagine they got a custom bearing machined for that.
Gear_One_Performance is offline   Reply With Quote
Old 02-21-2016, 11:11 PM   #8
Knshro13
Drives: 10 series FRS
you sure it's not the spring binding?
Knshro13 is offline   Reply With Quote
Old 02-22-2016, 01:45 AM   #9
Estey
Originally Posted by Teseo View Post
Complete top hat
Would I need the same exact one, or are aftermarket top hats interchangeable?
would this <http://passwordjdm.com/Buddy-Club-P1...4Wo2AjtkNNNNbb> solve the issue?
Unfortunately I dont have the time or capability :/
What exactly is that? I will definitely double check if this could be another possibility.
Old 02-22-2016, 02:07 AM   #10
Knshro13
When you turn your steering wheel, the strut also turns. It's possible that the springs are turning against the spring perch or top hat and making a "clunk", "boing", or "twang" sound.
There are a few ways to fix it.
1. You can spray white lithium grease like i did
or
2. purchase thrust bearings that suits your coilovers.
Above suggestion is assuming that the clunk you are hearing is the result of the springs binding.
If not, check your top hat/upper mount nut.
The Following User Says Thank You to Knshro13 For This Useful Post:
Teseo (02-22-2016)
Old 02-22-2016, 04:54 AM   #11
Teseo
Drives: frs
I dont know if aftermarket can solve it, sorry.
But mine does it (oem strut) and i just replace top hat bacuse was more simple to me swap it
Thrust/pillowball mount bearing clunk while steering VacantSky Issues | Warranty | Recalls / TSB 14 06-04-2015 01:43 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 06:41 PM
Need Advice: Broken strut mount stud... cobrabyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-22-2014 05:37 PM
FS factory strut/shock/mount JMoore412 Brakes, Suspension, Chassis 0 06-23-2014 03:41 PM
Those Who Have Cusco Strut Bar, Which Camber Top Mount Do You Run? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-03-2013 05:01 PM
