Software Tuning Discuss all software tuning topics. |
08-02-2017, 09:17 PM | #1 |
Drives: GT86 GTS
Idle issues on Ecutek
Hi,
My car was boosted last month and I am getting a few idle issues and wondering if the community can help. Issue 1 When the cars is cold I would be driving and coming to a stop (clutch normally engaged) the rpm's will drop and engine would stall. Normally only happens once or twice and when the cars warm its ok. Issue 2 When cars idling it will lean every so often causing the Revs to drop to 500 rpm and bounce back to normal. Any idea's what is happening?? |
08-02-2017, 11:36 PM | #2 |
Drives: FT86
Check your LTFT at idle and low rpm if its over say 10% you may have intake or exhaust leak if its over 10 %
Might be a speed density tune increase the rpm in the overrun fuel resume table at coolant temps above 140F , by 100 or 200 rpm , stock is 1300 try 1400 or 1500 increase base idle by 50 or 100 rpm adjust idle stability tables MAP |
The Following User Says Thank You to steve99 For This Useful Post: | Bobster (08-03-2017) |
Similar Threads | ||||
More damn idle issues... About to say bye to my frs | spatcha88 | Issues | Warranty | Recalls / TSB | 21 | 05-01-2015 02:16 PM |
How to fix the idle issues...according to jalopnik | jeebus | BRZ First-Gen (2012+) -- General Topics | 17 | 10-11-2012 05:06 PM |
With all these CEL/idle, chirp issues, should I postpone buying? | Iixii | Issues | Warranty | Recalls / TSB | 31 | 10-11-2012 04:18 PM |
Is there a way compel Toyota/Subaru to reveal what they know about CEL/Idle issues? | @Art_Mighty | Issues | Warranty | Recalls / TSB | 20 | 09-24-2012 09:37 PM |
Anyone worried about chirping/idle/taillight condensation issues? | JDM-dono | AUSTRALIA | 31 | 07-21-2012 01:12 AM |
