Old 05-02-2015, 12:05 PM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Removed undertray, now rubbing above 60 mph?
Was working on my car and removed the front metal undertray and the fabric one below the transmission.
I am planning some more work on the car soon so I left them off for now.
Thing is when I go above 60mph I get this awful sound of flapping/rubbing. The faster I go the worse it gets, I didn't even go over 65 because it sounds so bad.
It sounds like a fender liner or some type of plastic is flapping in the wind and rubbing on either the asphalt or some part of the car.
When I stop and look over the car I can't see any evidence of anything rubbing or dragging on the ground.
Anyone know what I should be looking for?
Old 05-02-2015, 12:58 PM   #2
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
Not sure either, but I experienced the same thing when I drove two weeks without that undertray. Anything under heavy acceleration caused a massive flapping sound.
R3NIK is offline   Reply With Quote
Old 05-02-2015, 01:00 PM   #3
ryoma
ryoma's Avatar
Are you sure its not the air getting trapped under there making the flapping sound?
Sent from my VS980 4G using Tapatalk
Old 05-02-2015, 01:05 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
There is one piece that shares two bolts with the fiber piece. If you didn't reinstall those and didn't take a piece off that went to the year wheels, I'd guess this is what you hear flapping.
At least, it's there on my BRZ, suppose it may not always be there on all models.
Old 05-02-2015, 01:10 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
I drove without my undertray when I installed my header so I could tighten the bolts after a heat cycle easier.
One of the plastic bits folded on itself after I hit 70 and started dragging on the ground.
There are a few things you want to ziptie or otherwise secure if you plan on running without the undertray. This was 2 years ago so I couldn't tell you exactly, but it should be easy to spot what needs to be checked
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 05-02-2015, 05:19 PM   #6
jvincent
jvincent's Avatar
IIRC, there is a wheel well liner that is secured with the bolts for the metal under tray. That was probably what was flapping.
Old 05-02-2015, 05:55 PM   #7
FirestormFRS
It's the drivers side tray behind the fiber cover. It makes a helluva racket and the longer you drive it the lower the speed you'll need to make it flap. Stick a bolt in the single hole until you get the bottom put back on
FirestormFRS is offline   Reply With Quote
Old 05-02-2015, 06:30 PM   #8
DJCarbine
Thupercharged
DJCarbine's Avatar
Yup, thats what it was
2013 FRS
Vortech V3 11psi
Undertray Bolts Part #'s and/or sizes smbstyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 03-15-2017 07:55 PM
Undertray rattling Tainen Issues | Warranty | Recalls / TSB 2 09-29-2014 09:27 PM
Will this set up be a rubbing issue Astroboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-02-2014 08:15 PM
How much rubbing is too much rubbing? Pokeguyjai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 12-10-2013 08:04 PM
Rubbing sound? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-15-2013 11:06 AM
