Old 11-12-2014, 10:54 PM   #1
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
OBDII boost gauge
I'd like to how if boost gauges that takes readings from the OBDII is accurate enough? Or is it better to use sensor (the type that has nylon tube to a control box which then sends signal to the gauge) or even mechanical type gauges?
Fizz is offline   Reply With Quote
Old 11-12-2014, 10:59 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I think its mainly just a matter of opinion. OBDII will be accurate, but there will be some lag depending on how you execute it. Electric boost gauges are good, and so are mechanical.
I installed a mechanical boost gauge on my last car and had no issues with it, so I could be a bit biased.
Bobblehead is offline   Reply With Quote
Old 11-13-2014, 01:05 AM   #3
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
The OBD2 gauges (I have a p3cars one myself) display what the ECU knows, it'll be dead on albeit with a tiny amount of lag. Idk about the stock MAP sensor but any properly scaled Omni is just as good if than the standalone senders. Seeing as how MAP is used in speed density it better be accurate :p
It'd be similar lag to an electronic needle gauge with a stepper motor. Mechanicals are the fastest but they can lose accuracy over time. The lag is such a small amount that unless you have a mechanical and digital next to each other you can't tell.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 11-13-2014, 01:34 AM   #4
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ok thanks guys. Yeah I'll be upgrading to an Omni 3 bar map sensor for my FI tune.
The p3cars gauge is what I'm looking at getting....
Old 11-13-2014, 04:31 AM   #5
s2d4
s2d4's Avatar
I got one if you want it, be back in Perth tomorrow too.
Old 11-16-2014, 11:38 AM   #6
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
For boost, if the MAP sensor is scaled the readings are correct.
However, for AFR you should use an external sensor (Innovate, AEM, etc.) wired to the analog signal wires on the p3 gauge. The factory air/fuel sensor is not totally accurate.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Boost Gauge Help Needed nlowell Forced Induction 19 09-28-2019 12:20 PM
Scangauge II w/ XGauge OBDII Gauge and Scanner smbstyle Interior Parts (Incl. Lighting) 1 10-10-2014 03:37 PM
Scangauge II w/ XGauge - OBDII gauge and scanner smbstyle Audio/Visual, Electronics, Infotainment, NAV 2 01-27-2014 09:10 AM
ATI Vent Pod 60mm & PLX DM-200 OBDII Scan Gauge Dustin@Dynosty Engine, Exhaust, Bolt-Ons 2 07-28-2013 02:21 PM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 08:11 PM
