Old 08-05-2019, 08:44 PM   #1
SmoothIsSlow
Spring perch clearance concern after camber bolt install
Hi all,
I recently added negative camber on my otherwise stock Performance Pack suspension via SPC camber bolts in the bottom holes and OEM 14mm in the top. Am getting -2.4* and -2.0* in the front. I just bought 225 45R/17 GT Radial SX2s off of the internet. My wheels are Enkei VR5 17x8 +45mm. I didn’t realize spring perch clearance could be an issue at as narrow as 225 (my winter tires were also 225 45R/17 on these same rims, but that was before I got the front camber bolts).
My tires are still on their way; could spring perch be an issue given my setup? I would like to have good clearance because this will be track set of tires/wheel. Thanks!
SmoothIsSlow is offline   Reply With Quote
Old 08-05-2019, 09:51 PM   #2
wparsons
wparsons's Avatar
I had a max of about -2.3* up front on 225/45/17's on 17x8 +45's before the clearance got too tight to go for any more. Every car is different so you might be fine at -2.4*, but might not.
flickr
Old 08-05-2019, 10:13 PM   #3
Thunder86
Thunder86's Avatar
Drives: 2018 Toyota 86 GT trim (Thunder)
Hate to piggyback off your thread, but I'm in a similar boat.
I'm running 18x8.5 +38 with 245/35/18 all season tires and TRD lowering springs with stock struts. Just received Eibach camber bolts in the mail.
Hoping to get -1.7° in the front, but I'm worried about spring perch clearance. Seen several people on the forums say they went with more camber and had zero rubbing issues.
[insert poor quality, phone-taken picture here]
Thunder86 is offline   Reply With Quote
Old 08-05-2019, 11:42 PM   #4
SmoothIsSlow
I just threw on my winters, which are also 225 45R17 on the sam wheels (17x8 +45mm). Had about 4mm of clearance between the perch and the tire. Just ordered 3mm spacers off of Amazon just in case. Hopefully these SX2s aren't any fatter than the winter sottozeros...
Old 08-05-2019, 11:57 PM   #5
Chuckable
Drives: 2017 Toyota 86
I ended up with about 2-3mm of clearance when I test fit 17x8+45 wheels with 245/40/17 Fallen Azenis tires and camber bolts with as much negative camber as I could manage.
I'm guessing that you'll be ok on 225s, but obviously check to be safe.
Sent from my SM-G973U using Tapatalk
Chuckable is offline   Reply With Quote
The Following 2 Users Say Thank You to Chuckable For This Useful Post:
dsc_pat (02-06-2022), SmoothIsSlow (08-06-2019)
Old 08-06-2019, 12:08 AM   #6
SmoothIsSlow
Thanks! @Chuckable is 2-3 mm of clearance safe enough to track with?
The Following User Says Thank You to SmoothIsSlow For This Useful Post:
TheRealBFKR (05-15-2021)
Old 08-06-2019, 12:16 AM   #7
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
If it were me that would be too close for comfort. TireRack recommends a minimum of 3mm clearance for autocross use. Track use can see more load on the tire sidewall, so might want a bit more to be safe.
https://www.tirerack.com/tires/tiret...jsp?techid=339
BlueWhelan is offline   Reply With Quote
The Following User Says Thank You to BlueWhelan For This Useful Post:
Old 08-06-2019, 12:38 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd shoot for 6mm min. Mine were that close and on a cold tire they would rub a bit if I wasn't careful.
NoHaveMSG is online now   Reply With Quote
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Leonardo (08-06-2019), Ultramaroon (08-06-2019)
Old 08-06-2019, 10:34 AM   #9
Chuckable
It was too close for comfort for me. If I'd kept that setup I'd have used a 3mm spacer.
Old 08-06-2019, 11:01 AM   #10
wparsons
wparsons's Avatar
I had about 3mm for dozens of lapping days and zero signs of rubbing on the perch.
flickr
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 01-29-2021 12:53 PM
17x8+45 with 8.3” tread width tires = tight spring perch to tire clearance Chuckable Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 06-03-2019 02:09 PM
Strut spring perch clearance ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-12-2018 10:34 PM
Spring perch clearance check iyoiyo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-22-2017 11:45 PM
Clearance to spring perch Gearhead1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-07-2014 06:56 PM
