Old 12-03-2018, 01:18 PM   #1
alexisv1012
Drives: lighting red
Grinding noise
https://video-lax3-2.xx.fbcdn.net/v/...=5C06B883&dl=1
The above noise happens most when the car is cold. At cold, it happens when at idle, but once warm it happens on every take off from zero (first and second gear). Once the car is going it stops making the noise even between gear shifts. I changed oils 8k miles ago (transmission, diff) and engine oil 2k miles ago. I'm past the warranty as I'm at 67k miles so I can't just take it to dealer. Please help.
alexisv1012 is offline   Reply With Quote
Grinding noise in neutral WGMGR Issues | Warranty | Recalls / TSB 28 04-12-2018 03:22 AM
Circular Grinding Noise DaBoBo21 Engine, Exhaust, Transmission 0 04-20-2017 10:28 AM
Grinding noise when AC on Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 07-11-2016 02:25 AM
Grinding noise during slalom JM197 Issues | Warranty | Recalls / TSB 9 08-11-2014 11:50 PM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 11:57 AM
