#2 |
You need a built engine to get the full potential out of it.
| The Following User Says Thank You to CSG Mike For This Useful Post: | Celigts (03-01-2015) |
#3 |
Drives: 2014 FR-S
Low end vs top end, take your pick:
![]() I would probably wait for the garrett turbo upgrade before making a choice. |
#4 |
Drives: 2014 Toyota FRS
I'm going to go with the Ptuning turbo ... Been wanting to pull the trigger for some time but wanted to waive for greddy to make their v2 kit ... and this one doesn't seem like it's up to my expectations.
| The Following User Says Thank You to Celigts For This Useful Post: | raven1231 (07-15-2016) |
#5 |
Drives: 2015 Subaru BRZ Series Blue
Is anyone running one of these?
http://instagram.com/cameronjones239
2015 Subaru BRZ Series Blue Build http://www.ft86club.com/forums/showt...09#post2002909 |
#6 |
Drives: Sterling BRZ Ltd
Is there any flow or wheel trim info on this 620Z?
#7 |
I've been running a PTUNING turbo for over 15k and put it through a PA winter. From my stand point PTUNING is a great turbo kit. Hasn't let me down yet. Still getting around 31 mpg when on travel days but only around 20 on back roads lol.
#8 |
What's that have to do with Greddy...?
#9 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
@rocketbunny86 is using it, maybe he can chime in.
#10 |
Hopefully someone can, I haven't found anyone running it yet. Curious how it'd be on a low boost set up with the stock block. Keep it around that 280-320whp with room to grow into the deep 300's-low 400's. Or if I'm better off running the 518 and swap to the 620 or Garrett down the road after the motor is built.
#11 | |
Drives: Toyota 86
| The Following User Says Thank You to ztan For This Useful Post: | cameronjones239 (06-02-2015) |
#12 |
Drives: 2017 BRZ yellow series
KIT is Fuked
I am running this kit, It over boost like crazy on stock motor. When greddy did there RND for this kit they tested it on a built motor with 10:1 compression. I have to put the stock exhaust back on to stop it from boosting to up 20psi.
#13 | |
Junior
Drives: a car
You dont have a boost cut on your tune?
#14 |
yea. but from what Greddy and my tuner tells me its a hardware problem and it cant be fixed with a tune.
there was 3 ways to fix the problem. 1) new Spings for the wastgate 2) external wastegate (not sure it will work) 3) or built motor. the problem was the wasgate not open with the compression differents |
| Greddy Base Map for FRS Greddy Turbo Kit | hiranak | Software Tuning | 10 | 10-27-2014 07:55 AM |
| *** [DECIDED] GReddy *** Full Blown vs GReddy | slisgrinder | Forced Induction | 31 | 08-13-2014 03:24 PM |
| GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) | NOTORIOUS.BRZ | Engine, Exhaust, Transmission | 21 | 09-24-2013 07:09 PM |
| GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. | 2JZ-DNA | Engine, Exhaust, Transmission | 46 | 04-19-2012 09:13 PM |
