Old 12-03-2015, 01:12 PM   #1
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Spec-D Headlights Retrofit?
Did anyone do the Spec-D Headlights retrofit yet? I'm not a light output snob, but the stock projectors are pretty shitty even when I upgraded to D2S HID Bulbs.
Was planning on getting some projectors from TRS and installing, maybe Morimoto but not sure if the size will be too small or too big.
YamahaR86 is offline   Reply With Quote
Old 12-03-2015, 01:14 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I Just got 55W HID's and light output is great, but the spread sucks !!
In for pics of the diffrence when you do this
Old 12-03-2015, 03:57 PM   #3
ryoma
ryoma's Avatar
be careful of using 55W HID bulbs in some projectors as not all projectors are made to handle 55W. if it isn't made to handle 55W, you will burn the bowl in the projector eventually and have a poor performing/useless headlight setup.
as for the spec-D, I'm pretty sure you can retrofit any type of projector from TRS in there but it will be a matter of how much work you are willing to put in. I believe the mini D2S projector is one of the easier to install
The Following 2 Users Say Thank You to ryoma For This Useful Post:
FRSBRZGT86FAN (12-03-2015), go_a_way1 (12-03-2015)
Old 12-03-2015, 04:01 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Thanks for the heads up! I like to live on the edge though
They have been in for over a year and so far so good.
Old 12-03-2015, 05:06 PM   #5
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Do you know the size of the mini D2S Projector? If I pull apart the Spec-D and measure it I may be able to do something if I know the sizes of the new ones I'm putting in, don't want to go in blind and have to test sizes.
Only retrofit I've done is a projector install for motorcycles. Even then, the only projector I've used in those are the FX-Rs. Install was simple enough, just need to build a bracket to mount it on and retain the adjustment points, then throw a overlay shroud on it.
Old 12-03-2015, 05:23 PM   #6
ryoma
ryoma's Avatar
you can find the dimensions for the projectors on the TRS website. here are the specs for the mini D2S
DIMENSIONS
Max Height:95mm
Max Width:100mm
Max Depth:145mm
O Lens Diameter:3 inch
X Lens Diameter:2.75 inch
Mounting Shaft: Diameter = 35mm
Lock Nut:Size = 46mm
Housing Depth:Minimum = 117m
Lens Diameter: 3"
when I retrofitted the FX-R, all I did was cut a hole in the back of my housing and JB weld it all together lol. however, it was simple (just time consuming to align properly) since I had a sealed beam housing. the housing for the 86 might be a bit harder.
The Following User Says Thank You to ryoma For This Useful Post:
YamahaR86 (12-04-2015)
Old 12-04-2015, 12:01 PM   #7
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
TheRetrofitSource Spec-D Retro-Quik Kit
The Following User Says Thank You to DustinS For This Useful Post:
Old 12-04-2015, 12:05 PM   #8
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Originally Posted by DustinS View Post
Are these for "our" spec-d though? I know Spec-D sells different lights for different vehicles and can't imagine they're all the same projector sizes.
One review on it and says
Lights are awesome, but the mounting holes on the plate does not line up the projectors perfectly, so drilling is required.
Besides that they are great
If that is all it needs and it fits I'll order it soon and maybe a write up.
Old 12-04-2015, 12:13 PM   #9
DustinS
DustinS's Avatar
I would imagine they are using the same projector. Makes it much easier/cheaper for them.
Note the addition message from TRS about fixing the brackets. You could call them up and ask, they have some of the best customer service you will find and can definitely help answer your question.
If you do call, it would be worth placing your order over the phone and seeing if you can get the new Mini H1 7.0 projectors in it. I can't remember if they have started including them in the kits or not, but the new Mini H1 7s are out, and much better than the 6's. Just bought them to upgrade my stock headlights from the 6's.
Morimoto Mini H1 7.0
Old 12-04-2015, 12:57 PM   #10
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Thanks for the info. I think I'll have to get in touch with Spec-D first to see if they'll release me any information regarding their projectors, then I'll start working on TRS towards aftermarket.
Old 12-04-2015, 01:50 PM   #11
DustinS
DustinS's Avatar
Interested in why you are going about it that way. Keep us updated.
Old 12-04-2015, 02:13 PM   #12
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
I want to see the sizing of the projectors, if it's the same for all of their products without having to actually open the headlights yet (no point in opening them up to measure and have to reseal when I don't even have aftermarket to put in).
Old 12-04-2015, 02:34 PM   #13
DustinS
DustinS's Avatar
Why not just call TRS, or email them. Then you only have one call, and if it is a yes, then can order.
- Edit: Contacted TRS, they said the reto-quik kit fits any spec-d headlight that uses a projector.
HID Retrofit w/blacked out OEM headlights Aztec Cosmetic Modification (Interior/Exterior/Lighting) 7 09-01-2015 11:03 PM
Spec D Headlights RetroFit Wyattkb Cosmetic Modification (Interior/Exterior/Lighting) 0 05-04-2015 12:15 AM
DIY Retrofit Winjet headlights post_break DIY (Do-It-Yourself) Guides 6 07-15-2014 12:13 AM
FS: TRS HID Retrofit Headlights for Sale tonystewart Exterior Parts (Aero, Lighting, Etc.) 31 04-15-2014 06:51 PM
