Old 02-07-2022, 12:27 PM   #1
Wingnutt
Drives: Pearl White 2014
Drivers side window stuck down, please help.
2013 FRS, no pushbutton start.
So this morning I got in the car and closed the door and it sounded odd. So I look and the drivers side window wasn't coming down the inch or whatever when I opened the door. So I lowered the window all the way and it was very sluggish, then I tried to raise it and it only came up a tiny bit then stopped. The window switches are flashing.
I looked this up and did the switch reset procedure to no avail.
Current symptoms:
Drivers side window down won't move any anymore.
Passenger side window CAN ONLY be lowered using the switch on the passenger side, it does not respond to the drivers side switch, otherwise it functions properly.
Buttons still flashing even after reset.
Have checked:
Fuses good
Window lock not on.
Unplugged Neg battery terminal to reset everything, no change.
The way the window was lagging I would suspect the window motor went out but I want second opinion(s) before I proceed in that direction.
Wingnutt is offline   Reply With Quote
Old 02-07-2022, 07:06 PM   #2
It's going to be either the motor or that driver's-side controller which is integrated with the switch panel.
Old 02-07-2022, 10:19 PM   #3
Wingnutt
It was metal fatigue, one of the bolts holding the motor to the door pulled through, caused assembly to be all off kilter, fabbed a sheet metal patch, drilled a hole and put it back together, works perfectly now.
The Following 6 Users Say Thank You to Wingnutt For This Useful Post:
bcj (02-08-2022), p1l0t (02-08-2022), sato (02-07-2022), soundman98 (02-08-2022), Ultramaroon (02-07-2022), x808drifter (02-08-2022)
Old 02-08-2022, 01:34 PM   #4
p1l0t
p1l0t's Avatar
I was going to say, sounds like it was in the wrong postion from where it expected to be. Glad you got it sorted out!
Cant find passenger window wire from drivers side remote.. help? luv85 Electronics | Audio | NAV | Infotainment 2 11-03-2020 10:13 AM
Drivers side window glass Akuma13 Want-To-Buy Requests 2 05-23-2017 01:25 AM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 02:08 PM
Drivers side Brake caliper stuck shut? ABS engaged all the time. gdrider77 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-20-2015 10:02 PM
Drivers Side Window (Not Seal) Mister Issues | Warranty | Recalls / TSB 20 12-16-2013 03:56 PM
