Old 01-26-2016, 11:47 AM   #1
ChrisP
8.5 inch wide wheel tire size?
I just oredered the Avid-1 AV20 wheels in a 18x8.5 with 33 offset and I was wondering wether I should put 235 section tires or 245? Wht do you guys run on an 8.5 inch wheel?
ChrisP is offline   Reply With Quote
Old 01-26-2016, 11:54 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
What are you plans with the car?
Old 01-26-2016, 12:07 PM   #3
ChrisP
Mostly a daily driver with a few autocros events here and there.
Old 01-26-2016, 12:10 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
245 if your gona do auto-x but just remember tire compound > tire width for traction
ChrisP (01-26-2016)
Old 01-26-2016, 12:13 PM   #5
djdnz
1337
Drives: 2013 BRZ WRB S/C
245/35/18 would be my suggestion, you won't see any stretch that way. Which color did you go with? Post some pics when you get them
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
ChrisP (01-26-2016)
Old 01-26-2016, 12:15 PM   #6
ChrisP
I got the black ones. Cant wait for them to get here! Will definitely post pics when I get them on.
Old 01-26-2016, 12:20 PM   #7
DAEMANO
Time Traveller
Generally speaking the tread width (not section width) should be within .5" of your wheel width.
So for example...
-Your wheel width = 8.5"
-Your tire make/model is = Michelin Pilot Super Sport
-Section width = 245 @ 9.8" (the tire measured from widest part of the tire sidewall to sidewall).
-Tread width = 9.0" (the width of the "treadded" portion of the tire).
This is within mfg specifications and will perform as expected on an 8.5" wheel. Mfgs also publish a range of rim widths that their tires are expected to work well. Here are all of Tirerack.com's measured widths for the same tire. http://www.tirerack.com/tires/Spec.j...omCompare1=yes
Tirerack measures every tire they sell. So their site is a decent reference point for tire specifications.
From everything I've heard, for AutoX you want the widest possible tire (255-275 on our cars). As noted above, compound is more important than width. However there are some tradeoffs to that if you're not going to be AutoX'ing regularly as people who do will be running the stickiest possible tire which are generally not great for DD (they wear fast, are noisy, they tramline in ruts, and they're kinda uncomfortable). If you're just AutoX'ing for fun and don't really care about time, then 235 or 245 won't make a lick of difference. Best of luck.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
ChrisP (01-26-2016), go_a_way1 (01-26-2016)
Old 01-26-2016, 01:42 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I ran 225s without issues.
You can do almost any size you want but moving up to 245s won't do much for performance increase over 235.
-alex
ChrisP (01-26-2016)
Old 01-26-2016, 03:08 PM   #9
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I run a 245/35/18 Michelin PSS on my 18x8.5 setup. They fit great, and don't have any stretch.
NotSoJDM is offline   Reply With Quote
Old 01-26-2016, 04:07 PM   #10
B$
86
Drives: Monogram Whiteout
On my 18x8.5 +33, I run a 245/35/18 with Hankook V12s.
I'm lowered on coils and I feel like I need to get spacers for the rear for a better stance
B$ is offline   Reply With Quote
Rijm/Tire size for a Rocket Bunny wide-body. StrayJay Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-03-2015 05:53 PM
Wheel/Tire size help!!! jordanlee2393 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-07-2015 06:11 PM
Tire/wheel size help needed gdrider77 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-28-2014 07:39 PM
225 or 255 RS3/EHP tire on 9.5" wide wheel unsurety Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-14-2014 01:11 PM
Help with wheel\tire size for a DD on Pro Kit B-R-Z Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-08-2014 01:06 PM
