Old 10-06-2015, 06:30 PM   #1
xkenx1995
Drives: 2013 Subaru BRZ
OFT Stage 2 stock headers
Would it be safe to use stage 2 EL 91 octane tune with stock headers?
xkenx1995 is offline   Reply With Quote
Old 10-06-2015, 06:50 PM   #2
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Not to be a **** but....I'm pretty sure it clearly says to only run stage 2 with aftermarket/catless headers. Why does everyone ask if something will be ok when it is advised against? /rant
If you are on e85 you can run the e85 stage 2 tune on a stock car.
Edit:
Running E85 on a stock car
http://www.ft86club.com/forums/showthread.php?t=67310
Definitely worth reading everything through multiple times before swapping over. Not a difficult process just make sure you understand what you are doing. There is also a stickied thread where you can post your data logs afterwards and will usually get helpful advice
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following 2 Users Say Thank You to Tectoniic For This Useful Post:
RustySocket (10-07-2015), Wayno (10-06-2015)
Old 10-06-2015, 06:57 PM   #3
xkenx1995
I read it, but I was digging around and saw a few that ran stage 2 on stock. Sorry I'm a noob and still slowly learning. I can just fill up on e85 then. Would it be UEL e85? Or EL 85?
Old 10-06-2015, 07:07 PM   #4
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You didn't say anything about e85 in your post
Old 10-06-2015, 07:12 PM   #5
xkenx1995
@Tectoniic answered my first question. I'm asking now if I can fill up on e85 on a stock frs/brz and use stage 2 with the EL e85 tune or UEL e85 tune.
Old 10-06-2015, 07:18 PM   #6
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
Your stock header is EL. There is an entire thread dedicated to E85.
I have found people to be very helpful here _provided you have done some basic research_ but they arent going to spoon feed you.
The E85 thread will be easy to find.
RustySocket is offline   Reply With Quote
Old 10-06-2015, 07:41 PM   #7
adamg
Drives: brz
sounds like you want to do stage 2 cause it sounds cooler than stage 1 but the only difference is the tune it adjusting for the catless headers
adamg is offline   Reply With Quote
The Following 2 Users Say Thank You to adamg For This Useful Post:
NyC Zn6 (10-08-2015), stock (06-15-2016)
Our Stage 2 E85 OTS map tested on stock car Shiv@Openflash Software Tuning 103 05-03-2019 08:41 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 05:48 AM
Near Stock v. OFT Stage 2 Dyno DarkSunrise Engine, Exhaust, Transmission 74 11-15-2014 10:48 PM
TOMEI UEL vs. EL headers (w/stage 2 OTS tune) UrmyboyBLUE Engine, Exhaust, Transmission 42 10-25-2014 03:16 AM
Anyone have an Exedy Stage 1/2 in stock? draggin_az Engine, Exhaust, Transmission 0 07-18-2014 09:13 AM
