Old 02-08-2015, 10:34 PM   #1
gabrielthethird
Drives: 2015 Scion FR-S
Buzzing/popping sound when HID fog light button is pressed. HELP!
Hello everyone
Installed my HID 3K Fog Lights this weekend. Plug and play no problem!
Long story short one light has been going out (sometimes on sometimes off). I made sure all the plugs were in tight and connected. I unplugged the H11 Male connector clip (the pins that plug into the power cable from the bulb) and plugged it back in.
Now I notice whenever I turn the fog light on/off switch on it makes a buzz/pop sound. Is this bad? What could it be? and why isn't this bulb staying on?
Any and all help would be appreciated!
gabrielthethird is offline   Reply With Quote
Old 02-08-2015, 11:03 PM   #2
White64Goat
Does the vendor you purchased them from have any technical advice on their website? What is making the noise, the switch or the headlight?
I'd recheck all the plugs/pins/connectors and your ground connections.
Old 02-08-2015, 11:07 PM   #3
gabrielthethird
I actually did some trouble shooting just now! I switched out the bulb that was working to the nonworking side and it came on.
It seems to be a faulty bulb.
I'll be sure to contact the vendor shortly
Old 02-08-2015, 11:10 PM   #4
White64Goat
The Following User Says Thank You to White64Goat For This Useful Post:
gabrielthethird (02-08-2015)
Light buzzing sound from driver-side dash BRZprime Issues | Warranty | Recalls / TSB 51 08-21-2015 10:34 PM
Buzzing sound under glove compartment? l0aded Issues | Warranty | Recalls / TSB 13 03-25-2014 07:20 PM
Buzzing / Compressor Sound from Gas Tank Area Spd229 Issues | Warranty | Recalls / TSB 14 12-06-2013 11:17 PM
Light popping sound when I steer, even when parked. Jar Issues | Warranty | Recalls / TSB 2 06-01-2013 06:27 PM
Buzzing sound(like hairclipper), gas tank region, car park for 4 hrs solma Issues | Warranty | Recalls / TSB 6 03-20-2013 03:04 PM
