Old 07-23-2013, 09:36 AM   #1
encity5
encity5's Avatar
Intake and water
I am about to pull the trigger on the perrin intake. But one concern/question I had was about any possibilities of it (or similar designed intakes) catching any water? Does the front bumper deflect any possible water from getting onto the filter?
My car is parked outside and it rains fairly regularly where I live. Just wanted to hear about any feedback or if it shouldn't be a concern at all.
Thanks
encity5 is offline   Reply With Quote
Old 07-23-2013, 09:45 AM   #2
dabocx
dabocx's Avatar
Drives: Scion FRS
Pretty much all the intakes all pull in air from where the stock intake pull in water including the perrin unit which goes exactly where the stock unit was, that place is higher than the block if im not mistaken.
So if you get water there you should be pulling out a life jacket :P
dabocx is offline   Reply With Quote
Old 07-23-2013, 10:10 AM   #3
frslee
Just drive it
Drives: 13' FR-S
Don't worry about it. As long as you don't submerge your filter, you should be good.
frslee is offline   Reply With Quote
Old 07-23-2013, 12:02 PM   #4
Rev Works
Rev Works's Avatar
Drives: 2013 STi
The way the Perirn is designed and where it sits, you really have nothing to worry about. Just dont go driving into any lakes and you should be fine lol
-Matt
Rev Works
Rev Works is offline   Reply With Quote
The Following User Says Thank You to Rev Works For This Useful Post:
PERRIN_Mladen (07-23-2013)
Old 07-23-2013, 01:31 PM   #5
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Thanks
As stated in the above posts, as long as you are not driving through lakes, you will be completely fine with our intake!
PERRIN_Mladen is offline   Reply With Quote
Old 07-23-2013, 01:49 PM   #6
encity5
encity5's Avatar
Thanks everyone! i figured i had nothing to worry about, but i just liked to double check.
The Following User Says Thank You to encity5 For This Useful Post:
Rev Works (07-23-2013)
Water in AC/Circulation Fan yeah2311 BRZ First-Gen (2012+) — General Topics 14 07-09-2016 10:08 AM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 03:57 AM
Water in trunk Spencer BRZ First-Gen (2012+) — General Topics 14 03-15-2013 11:17 PM
Water inside the car? YourFearlessLeader Issues | Warranty | Recalls / TSB 10 12-16-2012 05:55 PM
