Old 04-12-2014, 08:09 PM   #1
phrosty
High-flow cats?
Anyone have a HFC front pipe? I'd like a little meaner sound without waking up my neighbors going catless. How much more sound do you generally get with one?
edit: topic fail.
phrosty is offline   Reply With Quote
Old 04-13-2014, 09:26 AM   #2
wparsons
wparsons's Avatar
The difference in sound volume between stock and a high flow cat is bigger than the difference between a high flow cat and no cat. Any cat will help with rasp too.
Do you already have a cat-back installed? I put on my front pipe (2.5" Perrin catted) with the stock exhaust first and it was definitely noticeable if you really listened, but no one else would know. The cat back made way more difference in noise (2.5" Perrin resonated).
flickr
Old 04-13-2014, 09:28 AM   #3
akyp
Drives: 2012 86
Bear in mind the stock FP also has a muffler/resonator, while most aftermarket FPs don't.
akyp is offline   Reply With Quote
Old 04-13-2014, 01:31 PM   #4
phrosty
Good to know. I've already got a P&L catback installed -- it adds some deep noise but is still pretty quiet. Perhaps the front pipe won't add much noise after all.
Old 04-13-2014, 06:38 PM   #5
wparsons
wparsons's Avatar
Stock FP has a helmholtz resonator, not a muffler. It'll only reduce rasp, not actually reduce volume.
flickr
Old 04-13-2014, 06:44 PM   #6
Steve
Steve's Avatar
Drives: 6MT
A HFC front pipe, when compared to the stock front pipe, will noticeably wake up your catback. From experience.
Steve is offline   Reply With Quote
Old 04-18-2014, 09:46 PM   #7
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
i believe a high flow cat will be louder than the stock cat in the FP
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 04-19-2014, 09:06 AM   #8
wparsons
wparsons's Avatar
It absolutely will (also speaking from experience), but the absence of the helmholtz resonator won't do anything for the volume.
flickr
Old 05-25-2014, 06:29 AM   #9
BC-Boy
BC-Boy's Avatar
Drives: 2013 Brz sport-tech
I can confirm ! I went Greddy sp elite with little to no difference in sound
Invidia resonated frontpipe gave a very nice smooth sound
Then jdl uel header and overpipe WOW sounded like a pop can was loose in the muffler, lord of the rasp was born
Borla catback rasp gone but lord of OMFG thats loud was now born
then changed my invidia catless resonated frontpipe for a HFC thinking it would mellow out the sound, Wrong! the note has changed but still just a loud, good thing it doesnt stink anymore tho
The OEM front pipe REALLY quiets down the exhaust. im going back to it this is just to dam loud.
something else to note i found interesting, the inlet to the oem cat on the FP is very small, id say 2in, yet the rest of the FP is 2.5, also where it goes to donut gasket gets to 2.3in ?? i wonder if its worth chopping that silly little 2in section at the cat end of it and swapping it for a nice 2.5 with a nice thick flange ?
BC-Boy is offline   Reply With Quote
The Following User Says Thank You to BC-Boy For This Useful Post:
chas3wba0 (07-24-2014)
Old 05-25-2014, 04:58 PM   #10
lastexile1987
lastexile1987's Avatar
Drives: Lightning Red '13 Limited BRZ
Before I switched to the n1 catback I had a shop cut the resonator off and just do a straight pipe and I really did not like the sound of it. I'm not sure if they just did a bad job or if that was really just the sound of it but there was a lot of rattle when starting the car.
lastexile1987 is offline   Reply With Quote
Old 05-25-2014, 05:21 PM   #11
wparsons
wparsons's Avatar
Was it a helmholtz resonator (like the one in the stock front pipe), or was it an inline resonator?
Both will change the sound, but a helmholtz won't do anything for the volume. It will help a lot in reducing rasp/drone though.
flickr
Old 05-25-2014, 05:35 PM   #12
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I just ordered a JDL UEL header and JDL OP. JDL is making me a front pipe with a HFC and resonator. Will the car still be very loud? Rasp? Drone?
The rest of the exhaust is this: http://www.hks-power.co.jp/en/produc...rts/index.html
Anyone running a similar setup? This catback is supposed to be on the quieter side, at least that's what HKS says.
Bg8780 is offline   Reply With Quote
Old 05-26-2014, 01:10 AM   #13
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
MagnaFlow sell a 2.5" high flow catted and resonated front pipe for our cars. I have one on my BRZ and it's barely louder than the stock front pipe. JDL and Nameless will make catted and resonated front pipes as well but they are made to order and more expensive.
Yes it will be loud but don't expect any drone or rasp. You chose wisely!
The Following User Says Thank You to ATL BRZ For This Useful Post:
Bg8780 (05-26-2014)
Old 05-26-2014, 03:16 AM   #14
BC-Boy
BC-Boy's Avatar
that will be the best sounding exhaust known to man, that legamax sports exhaust is absolute perfection, from all the clips ive seen it has a very tiny rasp to it but while soundsing deep and aggresive, I have been debating for a longtime if i order this exhaust, how much did it cost you ??
Bg8780 (05-26-2014)
Gutting out the stock cats diss7 Engine, Exhaust, Transmission 90 04-02-2018 01:57 AM
Just replacing the stock cats? brillo Engine, Exhaust, Transmission 4 07-08-2015 12:12 PM
OEM cats only ? 350matt Engine, Exhaust, Transmission 7 11-26-2013 08:30 PM
I giggled... Cats have it made seven Off-Topic Lounge [WARNING: NO POLITICS] 51 12-21-2012 04:46 PM
Speed cats (or other driving shoes) Symbiont Off-Topic Lounge [WARNING: NO POLITICS] 25 06-15-2012 12:10 AM
