Old 08-21-2012, 01:48 PM   #1
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
USA front license plate mounting? Slimline bracket mount.. Help across the world :P
Hey guys,
Just finished up making Australian License plate holder prototypes, and was curious to know about the license plate mounting for people in other countries. Does anyone have a diagram or can help me with the locating holes for the numberplate mounts?
Here is how we mounted the AU plates:
Also I have noticed that someone said USA doesn't need license plates on the front at all? is this a state by state rule? As such, how do they mount the factory plate holder for your guys? Over here its two giant gaping rectangular holes on each side of the bar, where they slide a spring clamp that has a nut on the back. One for each side of the plate mount.
Anyways, any help would be appreciated, as I don't have access to USA plates and I am unsure if our design would be applicable for anywhere aside from Australia.
Based on how we did ours, maybe you can advise if this is possible or not on USA plates?
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline   Reply With Quote
Old 08-21-2012, 01:58 PM   #2
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Over here, at least in Canada where the front plate is required, the plate mount on the front is screwed into the black plastic "honeycomb" grill on the front....resulting in two less than desirable holes in the solid plastic part of the honeycomb...
Those two screws hold on the plate holder (through the bottom two holes), then the plate itself it mounted to that via the top two holes.
Rossman is offline   Reply With Quote
Old 08-21-2012, 02:02 PM   #3
WTF
WTF's Avatar
Thanks for the feedback.
So is yours the same as this:
Any chance you can shoot us a picture of what a Canadian plate looks like and how far apart its mounting holes are? I am interested to know whether our brackets would be at all useable in other countries or not.
Thanks again.
Mark
Old 08-21-2012, 06:44 PM   #4
Rossman
Rossman's Avatar
Its the same plate mount but instead of punching into the bumper, my dealer just put two screws here (red dots in your pic)
I ended up removing that shit and moving my plate down...
Old 08-21-2012, 06:47 PM   #5
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Yes, mine's mounted down in the grille area too.
The front plate is a state-by-state thing. Some require it, some don't, and some technically require it but rarely cite anyone for not having it.
MVJ1975 is offline   Reply With Quote
Old 08-21-2012, 07:11 PM   #6
bestwheelbase
Drives: 1985 P-Type
I think
1) Aussie plates are beautiful compared to this big USA things
2) Mounting it in the grill makes it look even worse, and then you're also covering the grill
3) The best route is to either ditch the front plate or move to Australia. :happy0180:
Old 08-21-2012, 07:32 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by bestwheelbase View Post
I think
Or the GrimmSpeed offset plate bracket.
Old 08-21-2012, 07:35 PM   #8
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Easy:
No holes in the car and I car remove it whenever I want very quickly without damage!
Old 08-21-2012, 08:10 PM   #9
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
If I could I'd use the Aus licence plate and holder but cost wise I'm planning on http://www.ft86club.com/forums/showthread.php?t=11676 .
Old 08-22-2012, 05:00 AM   #10
WTF
WTF's Avatar
Originally Posted by BlaineWasHere View Post
Easy:
you guys are lucky, over here they put 2x 2" x 1" holes on the front bar, for the locator clips, plus the holes in the mesh.. its crazy ..
Old 08-22-2012, 09:39 AM   #11
MarkMash
MarkMash's Avatar
Drives: Toyota 86
I reckon the new Maroon Queensland plates are bulk ugly (I prefer the older green ones) but dont think I cbf getting custom... not really my thing
Uploaded with ImageShack.us
MarkMash is offline   Reply With Quote
Old 08-22-2012, 09:45 AM   #12
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
It sounds like they hack up the front bumper for the factory plate holder here in the US as well.
Is there any reason you couldn't use a tow hook mount in AU? It's basically a threaded post that screws into the tow hook receptor with a plate-sized aluminum bracket that mounts on the other end.
-Justin
Justin.b is offline   Reply With Quote
Old 08-22-2012, 09:47 AM   #13
MarkMash
MarkMash's Avatar
Drives: Toyota 86
-Justin
pretty sure it has to be central here... (I could be wrong)
Old 08-22-2012, 09:48 AM   #14
Justin.b
I'd be surprised if it's not supposed to be centered here as well, but the rules vary by state and the enforcement in states where the front plate is required is inconsistent from one to the next.
-Justin
DIY: Center Mounting the Front License Plate WITHOUT DRILLING Neurytic DIY (Do-It-Yourself) Guides 28 05-14-2018 05:37 PM
Slimline Plates Plate Bracket eleu2166 AUSTRALIA 40 07-25-2012 11:45 PM
BRZ Front License Plate Custom Mount sure74 Cosmetic Modification (Interior/Exterior/Lighting) 14 06-29-2012 10:17 PM
License plate mounting ideas? csaba Scion FR-S / Toyota 86 GT86 General Forum 1 04-15-2012 09:58 PM
