follow ft86club on our blog, twitter or facebook. Interested in the FT-1? Check out FT1Club
ACE Headers
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 07-14-2012, 10:42 PM   #1
Neurytic
Neurytic's Avatar
Drives: 2013 Asphalt FR-S
Talking DIY: Center Mounting the Front License Plate WITHOUT DRILLING
Hello folks,
This DIY is for those of you that are required by law and want to mount your license plate front and centered to the car without drilling into the bumper for that clean clean look. I personally don't like mounting the plate to the tow hook or off-centered.
I've had this on for about 2 weeks now and can verify it stays on, can take rain, car wash, etc. etc.
Things you will need:
- Cruiser 79050 License Plate Holder (
Amazon.com: Cruiser Accessories 79050 License Plate Bracket, Black: Automotive Amazon.com: Cruiser Accessories 79050 License Plate Bracket, Black: Automotive
2x 3" bolts (9/16" I believe)
4x Big Washers
2x Regular washers
6x Hex Bolts
2 to 4 Zip Ties
Total Cost = ~$10 (4 for the holder and 6 for various parts)
The concept here is to mount it to the grill.
Procedure/Steps:
1. The large washer goes through the 3in bolt
2. With a bit of force and at an angle (it doesnt do any damage) slide the bolt with washer through one of the grill holes but do not push the bolt through all the way. You just want to washer to get caught behind the grill.
3. Once its in the hole, place another big washer through the bolt, in front of grill.
4. Take a hex nut and bolt it up to the washer, so it holds it all in place. (Tighten with a 10mm wrench). Basically you sandwiched the grill in between the two washers.
5. Now it looks like a big bolt horn sticking out of your grill (x2). On the tips of the bolt, place one hex nut 2 cm in followed by a washer, and then another hex nut. Tighten this nut/washer/nut combo WELL.
So the bolt up looks something like this now:
O#Ox----------------xOx
O is washer. # is grill. x is hex nut.
6. Using the Cruiser Plate, butt the end to the nut/washer/nut tip and zip tie the cruiser plate to the bolt (go easy on tightening the ziptie and adjust your angle to your liking before finalizing the tightness.
7. Stick a piece of foam the back of the lisc plate where the plate will meet the LIP (to prevent scratching). In the photo below, its a a photo looking up on the lip from the floor. The lisc plate has a piece of FOAM strip insulation (for doors) that I cut and stuck to help pad in case the plate ever touches the lip. Also, you can see the bolt tips in the photo.
8. Mount the lisc plate.
DONE.
I didn't want the plate to touch the lip. It doesnt. Perhaps it does at high speeds but I have a piece of foam on it. It is very stable and I don't feel super comfortable with using zip ties but will think of something else later.
I am also thinking of making a custom metal bracket that bend at 45 degrees for the tips of the bolt (instead of washer+zipties). IMO, if someone wanted to steal the front plate, they will just unscrew it.
NOTE: WHERE you set the washer+bolts in the GRILL also indicate how high your plate will sit above/below the lip. I like this height because it prevents the lip from ever getting "scratched" and the plate becomes the indicator first. NOT that i plan on it. EVER.
Neurytic is offline   Reply With Quote
The Following 9 Users Say Thank You to Neurytic For This Useful Post:
avusblue (07-29-2012), Bonburner (07-15-2012), calis5nest (07-30-2012), cobrabyte (07-15-2012), Dadhawk (08-22-2012), E_br4ke (09-18-2012), Guff (07-30-2012), Kwaziekeller (07-15-2012), nocurfew (07-30-2012)
Old 07-15-2012, 12:27 PM   #2
White64Goat
9/16 bolts would be about as big around as your index finger, I'm thinking they might be 1/4" ?
Old 07-15-2012, 06:52 PM   #3
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Nicely done... I was going to zip tie to the mesh, but I like this idea better. Adding to the DIY Directory.
http://www.ft86club.com/forums/showthread.php?t=7365
Old 07-15-2012, 08:32 PM   #4
xcelir8brz
Drives: 2013 BRZ Limited
Works on FR-S only. Not the BRZ.
xcelir8brz is offline   Reply With Quote
Old 07-15-2012, 10:24 PM   #5
Bonburner
Bonburner's Avatar
Drives: M/T Argento FRS
I've been debating paying that $80 for a grimspeed/perrin but this looks better to me not just by cost - symmetry ftw.
Old 07-16-2012, 05:16 PM   #6
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
really nice... i wish my dealer hadn't drilled the holes though. Anyone know where to buy another grill?
Style is offline   Reply With Quote
Old 07-19-2012, 04:53 AM   #7
Mo707
Mo707's Avatar
dealer drilled thew my grill...
The top bolts started scratching my paint. So it just took it all off.
Mo707 is offline   Reply With Quote
Old 07-19-2012, 07:10 AM   #8
Shiny
Drives: 05 Ford F150 Scrow
I would not do that here in the UAE. It is hot and that would put strain on the radiator, by reducing the air flow to the radiator. It reached 50 C (122 F) yesterday.
Hear it is a must to have front and rear Plates. But we have the option of tow different sizes. Don’t now what is the size thou. but one is narrower and longer that can be used at front.
Wish I can do it thou. Locks OEM, love it.
Shiny is offline   Reply With Quote
Old 07-19-2012, 10:00 AM   #9
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Man oh man I hate front plate laws.
Aftermarket options are nice and flush but this is a great free option. Good work!
FT-86 SpeedFactory is offline   Reply With Quote
Old 07-19-2012, 12:22 PM   #10
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I could see that a light tap by hitting a curb would take out your grill. Drive carefully.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 07-29-2012, 03:12 PM   #11
Rossman
Rossman's Avatar
Drives: '13 FR-S, '02 Accord
I was hoping for answer to the same!
Rossman is offline   Reply With Quote
Old 07-30-2012, 12:24 AM   #12
Sleeperz
Drives: 1982 Toyota Corolla Coupe SR5
Is it possible to drill underneath the bumper to install a couple angle brackets to attach the top of the license plate to. Drilling underneath the bumper you do not see it.
My Corolla license plate is mounted using only the top two holes and the OEM brackets are welded underneath the bumper.
Sleeperz is offline   Reply With Quote
Old 08-21-2012, 10:56 PM   #13
pinoyplaya
Drives: WRB MT-BRZ LMTD
I havent really inspected the front grills much and etc. but why doesnt it work on the BRZ? I was thinking of doing this
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 09-13-2012, 05:43 PM   #14
E_br4ke
Drives: FRS 6MT
+1 on symmetry comment. Will be using this once my plates come in.
E_br4ke is offline   Reply With Quote
licesnse plate front diy
Search this Thread:
Advanced Search
CA Front License Plate Law? ashtray Southern California 24 09-11-2012 05:14 PM
Front License Plate Replacements Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 14 05-14-2012 06:25 PM
License plate mounting options (update: photos added) Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 27 04-16-2012 03:21 PM
License plate mounting ideas? csaba Scion FR-S / Toyota 86 GT86 General Forum 1 04-15-2012 09:58 PM
Front License Plate Location Polish Person Scion FR-S / Toyota 86 GT86 General Forum 44 12-16-2011 12:04 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
