Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
04-01-2021, 07:18 AM | #1 |
Drives: Widebody 86/F56 Mini Cooper S
Max Jack Stand Size?
I have 6 ton jack stands laying around that I was thinking of using to place under the 86. But seeing the size of their arm is making me think they are too big for our cars. The length of the arm is about 11 cm across. The 4 jack points seem rather small (the subframe is honestly only like an inch across behind the groove)
Wanted to ask if it is fine or I have to get smaller ones? To be honest I prefer using the 6 ton ones just because of how big and sturdy they are, paired with my lack of trust being under jacked up cars :3 |
04-01-2021, 10:39 AM | #2 |
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
If the supporting arm itself looks like it will miss the jack points and jab the body of the car, don't use them. I find smaller 3 ton jack stands easier to get in and out of underneath the car so I'd recommend just using them. They support more than enough weight still.
Additionally, while I can't really recommend Harbor Freight jack stands, they do make pretty good rubber jack stand top covers that provide a little better support and care for your car. https://www.harborfreight.com/automo...-pc-63373.html
The Following User Says Thank You to gkubed For This Useful Post: | Hamza (04-01-2021) |
04-01-2021, 02:53 PM | #3 | |
Yeah I think my best option is to raise the car and see where the arms of the stand would rest, then trade in for the smaller 3 ton ones. I'm not in the US so we don't have harbor freight. The ones I have are Chinese (it's the only thing you can find here for less than $90ish) but they do look and feel really solid |
04-01-2021, 05:28 PM | #4 |
The pinch weld area is not half inch specific. The notch is to keep the simple stock jack from slipping. The floor jacks most of us use spread the load out. Only the show car and OCD people worry about the paint and possible damage in that area.
The Following 3 Users Say Thank You to ls1ac For This Useful Post: |
04-02-2021, 12:02 PM | #5 | |
Also side note I may have bent one of the grooves :3 not all of it idk it's in like layers one of them is bent don't know from when, any way to fix that? Not gonna lie, I really don't like this thing groove design. My other cars are all Germans and I really like a flat spot way more |
04-02-2021, 12:18 PM | #6 |
When i read the thread name i thought it was about the MaxJax. They work great.
Just put the jack stand next to the notch in the pinch weld. Some OCD's cut a hockey puck to save the paint. This area is designed to lift the car. |
The Following User Says Thank You to ls1ac For This Useful Post: | Hamza (04-02-2021) |
04-02-2021, 01:07 PM | #7 | |
Sorry to be asking such basic questions, this groove notch stuff is just getting to my head cause they bend so easy and my brain doesn't cooperate with knowing that I jacked a car on a piece of metal 1 mm in width |
04-02-2021, 02:01 PM | #8 |
Drives: Scion FR-S Series 10 #2462
Get some of these. They help a lot.
04-02-2021, 02:28 PM | #9 | |
Planning summer road trip
Drives: 2019 Sport-tech RS. City car: GD3
There has been a really good write up about how to SAFELY jack up a twin a decade ago(already ?) See here to put your mind at ease if you want to do this right or familiarize with the options, we want to see you back. https://www.ft86club.com/forums/showthread.php?t=10111 with some |
The Following User Says Thank You to The Red One For This Useful Post: | Hamza (04-05-2021) |
04-02-2021, 03:19 PM | #10 |
JDM Vaping Stance Nation
Drives: 2013 White
Use the pads that are mentioned. When I changed my clutch I wish I had them big boy jack stands since I struggled dropping the tranny and pulling it out.
Clueless
04-05-2021, 03:09 AM | #11 | |
If I be honest it still doesn't make sense to me how thin metal is strong enough to bare forces when tightening/loosening bolts down there. Also the scissor jack that comes with the car avoids putting weight on the metal piece completely but puts it on either side. These are the only types of stands that are possible to get so idk. It did the job yesterday but just in case I stacked up bricks on both front and rear tyres, but I'm skeptical of taking the exhaust out on it, just seems to slippery? |
04-05-2021, 02:29 PM | #12 | |
The Following 2 Users Say Thank You to MJones_RB For This Useful Post: | Hamza (04-05-2021), soundman98 (04-05-2021) |
04-05-2021, 02:58 PM | #13 | |
Drives: -
Friendly reminder: read the stickers on your stands. Bend that safety tab in already. |
The Following User Says Thank You to Transport3r For This Useful Post: | Hamza (04-05-2021) |
04-05-2021, 03:39 PM | #14 | |
Similar Threads | ||||
Changing oils by myself, are these a recommended jack+jack stand? | btan219 | BRZ First-Gen (2012+) -- General Topics | 67 | 10-23-2021 03:54 PM |
Custom made Jack stand supports | AlexTheGreek | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 03-04-2015 05:01 PM |
jack stand body contact behind pincheld | tjc5268 | BRZ First-Gen (2012+) -- General Topics | 2 | 04-12-2014 04:15 AM |
Jack stand points | xxscaxx | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 09-12-2013 09:01 PM |
Jack/stand system | Mr.Corvus | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 03-31-2013 12:02 AM |
