Drives: 2017 Toyota 86
Hello, I recently noticed a new sound coming from my engine bay, both from inside and outside of the car. I did some troubleshooting to try and isolate the issue and I will share my results. Before that, the sound is best described as chirping in my opinion, but unsure.
The sound is only apparent when the clutch is not engaged, so if I press down on the clutch the sound goes away, which leads me to believe it is an issue with the transmission/clutch. The sound is there as soon as the car starts up and continues to be heard throughout each gear/speed/rpm with the same volume and tone. The sound appears to be intermittent in regards to not hearing during certain start-ups and for the remaining drive. There was no particular event that happened prior to the sound becoming first noticeable. I have had a few instances where I tried shifting up a gear, but mistakenly went into neutral and hit the throttle as if I went into the next gear which has caused me to redline. Additionally, when this happens the stick vibrates violently and hard to switch gears. It is also worth noting that it is sometimes very difficult to put the car into first gear and reverse, also occasionally difficult to switch to other gears when upshifting which is what causes me to accidentally go into neutral. I will attach some audio clips of the sound from different angles and positions. https://clyp.it/n2gz3ivn?token=521ef...7d63320ceaa46e https://clyp.it/4v4icmv5?token=b7f12...1bd1d947205230 https://clyp.it/pr2joadd?token=72312...1eb876a3c3f9e3 https://clyp.it/cmklydz3?token=05ab8...dab3d508de34c1 If anyone can shed some light on the issue in regards to what is wrong and how to fix it, that would be greatly appreciated. I would like to gather as much information as possible before going to the dealership as I am currently under warranty. Vehicle: 2017 Toyota 86 Miles: 25,000 |
#2 | |
Drives: 2016 FR-S
But this: "I have had a few instances where I tried shifting up a gear, but mistakenly went into neutral and hit the throttle as if I went into the next gear which has caused me to redline. Additionally, when this happens the stick vibrates violently and hard to switch gears. It is also worth noting that it is sometimes very difficult to put the car into first gear and reverse, also occasionally difficult to switch to other gears when upshifting which is what causes me to accidentally go into neutral." THAT I certainly dont know what it may be or if my suggestion for ToB would even be remotely related. Truth be told it sounds like "a particular event" did indeed happen. |
| Transmission Synchro/Output Shaft Noise After a Concerning Sound | Rybot | Engine, Exhaust, Transmission | 7 | 07-01-2022 12:06 PM |
| Helicopter Sound from Transmission | nvus_frs | Engine, Exhaust, Transmission | 17 | 03-20-2016 05:32 AM |
| Sound of (possible) dead clutch or a bad transmission? I hope neither | joshlx | Issues | Warranty | Recalls / TSB | 13 | 08-06-2015 03:46 PM |
| Transmission Dry Sound & Bogging | jjkerr626 | Engine, Exhaust, Transmission | 3 | 06-11-2013 01:10 AM |
| Transmission Sound... | chipz91 | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 08-21-2012 02:30 PM |
