Old 01-21-2018, 05:24 PM   #1
Newtothegrounds
Newtothegrounds's Avatar
Drives: 2016 FRS
Anyone know the noise?
Anyone know what is causing this noise? Car is not on, just let in ignition. It does not stop and is extremely load as in you would almost have to yell at someone if there beside you. Took video of it below.
2016
13,000KM
Newtothegrounds is offline   Reply With Quote
Old 01-21-2018, 05:36 PM   #2
Yikes ...... this has been the week of strange noises ......
So, the engine is NOT running ..??
The ignition switch is ON ..??
Does the sound stop when the ignition switch is OFF ...??
Come back ......
Old 01-21-2018, 06:08 PM   #3
Newtothegrounds
Drives: 2016 FRS
Correct NOT running, key is just in ignition, happens on full accessory. Should have added its coming from throttle body area (intake manifold).
Video does not justify how loud it is, climate controls turned off so not a blower fan for heating or cooling and not the rad fan.
Old 01-21-2018, 06:55 PM   #4
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
If it were me, I'd use a stethoscope or hose/rod to determine where the noise is coming from then start pulling fuses or dis-connecting connectors to see what makes it stop.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
humfrz (01-21-2018)
Old 01-21-2018, 07:09 PM   #5
Bubba suspects the horn is sick and stuck - he says to pull the fuse or rap on the horn with a BF screwdriver .......
Bubba ain't usually right ...... but, he tries ......
humfrz for Bubba
BirdTRD (01-21-2018)
Old 01-21-2018, 07:09 PM   #6
J Greg BRZ
Drives: 2016 Subaru BRZ
Why not just drop it off at the dealer? I assume your car is still under warranty at that mileage and MY.
J Greg BRZ is offline   Reply With Quote
Old 01-21-2018, 07:17 PM   #7
....... THAT ain't no fun ........ we're gonna keyboard fix this damn problem ........
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Overdrive (01-21-2018), spike021 (01-22-2018), strat61caster (01-21-2018)
Old 01-21-2018, 07:52 PM   #8
Newtothegrounds
Drives: 2016 FRS
If possible I try not to go to the dealership for anything I've had issues in the past with other vehicals that had to get legal. It did go in my favour but I hate going to the slime bag place.
Old 01-21-2018, 08:18 PM   #9
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Mine has done this ever since I can remember, and from what I diagnosed, it's related to the throttle body stepper motor. I believe you are hearing a particular resonant frequency emitting from the internal electromagnets that are trying to maintain the stepper's position. The reason you can hear it just in accessory is because the engine will mask that sound while running.
I really don't think it's anything to worry about.
Jesse36m3 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse36m3 For This Useful Post:
humfrz (01-21-2018), Ultramaroon (01-21-2018)
Old 01-21-2018, 09:05 PM   #10
J Greg BRZ
I do all my own preventative maintenance myself, so I don't take my car to the dealership either. However, I would make an exemption if something were to fail under warranty. I certainly wouldn't pay for it out of my own pocket.
I hope you get it resolved either way though. Best of luck.
Old 01-21-2018, 09:31 PM   #11
It's just the throttle servo holding idle position. Have someone slowly step on the throttle while you're listening. It's fine.
Old 01-21-2018, 09:48 PM   #12
Newtothegrounds
Drives: 2016 FRS
K thanks for the info guys. I'll try the throttle it should change even if it's a tiny bit like your saying.
Old 01-21-2018, 09:53 PM   #13
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
That is quite loud. Can you hear it like that in the cabin? Being so close to the firewall I have to figure it goes through pretty clearly.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 01-21-2018, 11:52 PM   #14
Yaaaaa.........Jesse36m3 fixed it ........
Confirmed by @Ultramaroon ...... so, it must be right ......
Yep, I checked mine and it does it too ....... but not nearly THAT loud ......
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 11:21 PM
Help with a noise please. Crosscharge Issues | Warranty | Recalls / TSB 5 07-18-2014 03:47 PM
Is it THAT noise? Taro Issues | Warranty | Recalls / TSB 5 09-23-2013 10:21 AM
Fan noise? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 3 07-30-2012 06:22 PM
