Old 06-15-2017, 09:14 PM   #1
SK-Frs
Drives: 2016 FRS
100w 9005 bulbs
Anyone know if it is safe to run 100w halogen bulbs on the frs DRL?
I just recently bought these cause I want the white light DRL and realized it was 100w while car stocks are 65w.
https://www.amazon.ca/Infinra-5900K-...7575429&sr=1-1
SK-Frs is offline   Reply With Quote
Old 06-15-2017, 09:32 PM   #2
Cole
Not a troll
Cole's Avatar
No
Cole is offline   Reply With Quote
Old 06-15-2017, 10:46 PM   #3
Chimera
Drives: FRS
Definitely not safe
Old 06-16-2017, 03:31 PM   #4
SK-Frs
Drives: 2016 FRS
would a heavy duty ceramic harness help? I know its mostly about the wire melting together, but if i get a harness that can stand the heat, wonder if that will make it safer.
Old 06-16-2017, 03:47 PM   #5
Darkrune
Darkrune's Avatar
Drives: 2017 86
The housing would melt and there is risk for fire.
Darkrune is offline   Reply With Quote
Old 09-05-2017, 06:41 PM   #6
xXMirageXx
Drives: 2015 1.0 series FRS TRD
I believe thats 100 watts per set so 50w each bulb, but i would double check with seller just to be safe. My frs HID is 35w per bulb so total watts is 70w and i have replaced my HID with LED bulbs 32w bulbs so total would be 64w per set.
xXMirageXx is offline   Reply With Quote
Old 09-06-2017, 07:46 AM   #7
Chimera
Drives: FRS
Even if that were the case I would stay away as the seller would not be following proper standard conventions for expressing specifications then.
Old 09-07-2017, 07:01 PM   #8
xXMirageXx
I just checked the link and if you scroll down to the product description it says 100w package..... so they are saying the total watts for the set is 100w so 50w each bulb but again i would just confirm to be sure. my set of leds are 72ish watts per set and they produce about 7000 lumens and they are 6k white if that matters to anyone XD
Old 09-09-2017, 02:34 PM   #9
Poodles
Drives: 2015 Series.Blue
Definitely 100W per bulb. Bulbs aren't rated by package.
Also, HID's while running pull less power than a halogen, but their starting needs are higher.
Also, there's no reason to go to LED's on an HID setup...ever.
8" 100w Bazooka Tube norcalpb Audio/Visual, Electronics, Infotainment, NAV 3 04-04-2017 07:06 PM
FS: 9005 LED&7443 LED Switch Back bulbs Rican_D Exterior Parts (Aero, Lighting, Etc.) 6 01-16-2015 12:35 AM
FS: GP thunder 7500K halogen Bulbs (H11 and 9005) KkSc Canada Classifieds 1 07-19-2013 02:03 PM
Retroquik kit bixenon + functional led 9005 drl bulbs? eddieEndo Cosmetic Modification (Interior/Exterior/Lighting) 12 04-27-2013 06:06 AM
HELP! 100w bulbs? Navadv Cosmetic Modification (Interior/Exterior/Lighting) 4 01-25-2013 12:32 PM
