Old 08-30-2014, 12:33 PM   #1
Flako
Drives: Asphalt scion frs
Unhappy Window scratches
My windows are getting some really bad scratches anytime I roll my windows down, I have taken it to the dealer (major douches) and they said it was dirt that caused it tough luck. I saw in a thread someone said there was a tsb out there but all I have found is this
tsb info:
S-SB-0009-14
Outside Door Weatherstrip - Multiple Concerns
Some 2013 – 2014 model year FR-S vehicles may exhibit multiple concerns from the Outer
Weatherstrip (belt molding).
The cross section of the weatherstrip has been revised to limit the amount of water passing into
the door. If the felt attached to the window stabilizers/guides accumulate water, the vehicle may
also make noise from the stabilizers/guides during window operation. In some cases, the felt on
the stabilizers/guides may freeze to the window or detach from the plastic backing and damage
the window.
Symptoms may include:
• Noise coming from the weatherstrip during window operation, especially when wet.
• Loosening of the weatherstrip from the door.
• Inversion of the weatherstrip during window operation.
• Noise from the stabilizers/guides during window operation.
• Scratches on the glass from worn stabilizers.
This bulletin applies to vehicles produced BEFORE the Production Change Effective VIN
shown below.
MODEL PRODUCTION CHANGE EFFECTIVE VIN
FR-S JF1ZNAA1#E8705465
The dealer couldn't find this so I was wondering if anyone had any information on this?
Flako is offline   Reply With Quote
Old 08-30-2014, 12:39 PM   #2
Jrryjms07
Jrryjms07's Avatar
Drives: 2013 Firestorm
Mine make the same a noise too. Because I work a a Honda dealership. They said it's just dirty and needs to be clean. I haven't done it yet.
Jrryjms07 is offline   Reply With Quote
Old 08-30-2014, 12:44 PM   #3
Flako
I did mine but it is leaving really bad scratches ...;(
Old 08-31-2014, 06:02 PM   #4
Knickstape
Knickstape's Avatar
Drives: '13 FR-S (Asphalt)
I've got the same problem but only on my passenger side. Was thinking of polishing it out, but if it's gonna keep happening i don't know
Opti-Guard, 35% Tint, Perrin 2" Antenna, Helix Side Markers, Valenti Tails, Carsmo Armrest, LED DRL Strip // UniChip, Perrin CAI & Inlet Tube, Perrin Cat-Back Exhaust, Grimmspeed Super-Loop Header.
Knickstape is offline   Reply With Quote
The Following User Says Thank You to Knickstape For This Useful Post:
Flako (08-31-2014)
Old 08-31-2014, 07:22 PM   #5
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
There's a bulletin on it and any reputable dealership should be taking care of it on the spot for you.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following 2 Users Say Thank You to Silver Ignition For This Useful Post:
Flako (08-31-2014), FRSBRZGT86FAN (09-02-2014)
Old 08-31-2014, 07:57 PM   #6
CokeSlap
Drives: 2014 Monogram FRS Whiteout
This.
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl
CokeSlap is offline   Reply With Quote
The Following User Says Thank You to CokeSlap For This Useful Post:
Flako (08-31-2014)
Old 08-31-2014, 08:21 PM   #7
Flako
Only problem is I can't find anyone with the bulletin...
Old 09-01-2014, 11:45 AM   #8
Silver Ignition
APEXHNTR
the dealership should be able to pull it up…I might be able to link a PDF to it…
EDIT: attached the bulletin
#1867 of 2500
Flako (09-01-2014), Sigh-on-Rice (09-02-2014)
Old 09-01-2014, 02:47 PM   #9
Flako
You sir are a lifesaver! Do you think they will replace the windows?
Old 09-01-2014, 02:52 PM   #10
Silver Ignition
APEXHNTR
The TSB doesn't specifically specify replacement of the glass, but they should be replaced on an as-needed basis. We've replaced glass on two of the cars we've done at the dealership.
#1867 of 2500
The Following User Says Thank You to Silver Ignition For This Useful Post:
Flako (09-01-2014)
Old 09-01-2014, 06:08 PM   #11
Flako
Where they this bad?
Old 09-01-2014, 11:04 PM   #12
Silver Ignition
APEXHNTR
holy shit not even close to being that bad...
#1867 of 2500
Old 09-02-2014, 12:32 PM   #13
Flako
Yup I got told tough luck sand probably did this, I guess I will try another dealership
Old 09-02-2014, 04:39 PM   #14
hypercarfanatic
Drives: Own F-150XLT, Lexus RX300
Obligatory "its totaled, buy a new one" and "damn, dealerships suck" comments
hypercarfanatic is offline   Reply With Quote
The Following User Says Thank You to hypercarfanatic For This Useful Post:
8R6 (09-30-2014)
windows
Scratches on Outside of Driver's Window NewmarketBRZ Issues | Warranty | Recalls / TSB 56 09-26-2018 05:57 PM
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 03:14 PM
Scratches from Window Usage? DieselxIndustry Issues | Warranty | Recalls / TSB 27 03-08-2015 09:03 PM
Scratches on front window B-R-Z BRZ First-Gen (2012+) — General Topics 2 06-22-2014 11:49 AM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 08:25 AM
