Oil Catch Can for Turbo Setup
Which brand oil catch can do you guys run with your turbo setup? Thanks
#2 |
Drives: Velocity Orange 86 GT
Radium Dual setup. Excellent fitment on left and Right hand drive. Right hand drive just had to tweak the master cylinder hardline. They come with quality made brakets and all the required hardware. Thats them in my setup.
| The Following User Says Thank You to Northwest86 For This Useful Post: | tonytduc (11-30-2015) |
#3 |
Drives: 2013 BRZ black
#4 |
Drives: 2025 BRZ, ex-2012 GT86
| The Following User Says Thank You to Efferalgan For This Useful Post: | DarkPira7e (12-18-2017) |
#5 |
Wow thats alot. Boosted application I presume?
#6 |
Yep. HKS V2 SC. There is link to my thread on this in the previous post.
#7 |
Sarcastic SOB
The oil location indicates blowby from the crankcase vent, not the PCV. I don't think there's reason to thing there's anything wrong with the can you have.
#8 |
This AOS combines both vent routes into the same cavity, so it's clear that the oil comes back to the engine via the intake but it's not certain that this oil comes from the crankcase vent initially. The 2 lines are not isolated.
#9 |
Sarcastic SOB
My catch can intercepts blow by from the PCV and returns it to the intake manifold where the PCV normally does. The crankcase vent returns oil to the intake before the throttle body. I thought perhaps your setup was similar in which case this would explain the oil in the throttle body.
#10 | |
#11 |
Sarcastic SOB
Wow it seems a mystery how oil ends up in front of the butterfly valve.
#12 |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Or you can... you know... vent it to atmosphere?
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#13 |
Drives: Late 2014 Subaru BRZ
I purchased a universal catchcan that vents to atmosphere. I had to make a bracket that holds the can to the battery. I deleted all pcv valves and have 1/2 hoses leading to the catch can. Installed a 1/2 barb where the crankcase pcv was.
The only thing I may do is delete the catchcan filter and run a hose from the top of the catch can to near the trans or tap the turbo air filter and have it recycling. I can smell oil/gas with the AC on now ![]() I used 1/2 hoses because the oil doesn't get as much build up compared to tiny hoses that alot of theses kits use. Cost to make my own setup was $130 including catchcan, barbs, hoses and metal to make bracket. Before catchcan and pcv delete I was getting tomuch pressure in my crankcase and it was causing mystery oil leaks. Ever since the install I've had zero leaks.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
| The Following 2 Users Say Thank You to GsxrMe For This Useful Post: | #maverick# (03-22-2016), ORGANIZED-CHAOS (04-02-2017) |
#14 |
Drives: 2014 FR-S
I don't know why ppl VTA. It stinks and the fumes are likely gonna stay trapped in the engine bay, leaving residue. It's the easy way out, if you ask me. Do it right and catch it or recirculate it.
| Radium Catch Can Setup? Turbo idle problem | drambo136 | Forced Induction | 36 | 11-11-2018 08:05 PM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 07:36 AM |
| FS: Radium Universal Catch Can - BRZ/FR-S Setup | F1point4 | Engine, Exhaust, Bolt-Ons | 8 | 04-09-2015 02:08 PM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 11:48 AM |
| High HP turbo catch can setup | Dan@AWD | Forced Induction | 32 | 08-06-2014 09:52 AM |
