| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2015 Fire
Replaced liquids with motul 300.... Car stalls...
Hey guys looking to see if anyone might have some advice while I run the CEL codes.
Swapped over both tranny and diff fluids to motul 300. A day or two later the idle started sounding a little weird. Like a Diesel engine or if something was loose (slight knocking but only at idle) Last night I drove the car and at a red light it bugged rough idle and boom shut off... any ideas?
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued... |
#2 |
Drives: 2014 BRZ Limited SWP
Any intake mods?
Dirty/BAD MAF can do that
#TrackDayBro
| The Following User Says Thank You to Kuri For This Useful Post: | Vroomin86 (11-03-2015) |
#3 |
Drives: 2015 Scion FRS - Raven
Sounds like your motor has no oil.
| The Following User Says Thank You to TRAKRAVN For This Useful Post: | Vroomin86 (11-03-2015) |
#4 | |
Drives: WRB BRZ
| The Following User Says Thank You to Fred E For This Useful Post: | Vroomin86 (11-03-2015) |
#5 |
Drives: 2014 SWP BRZ, MT
If that's the only thing you've changed for sure, double check and make sure your trans and diff aren't leaking. The fluid change itself is highly unlikely to cause that, unless the fluid leaked out and is causing significant friction. What codes came up?
The answer is racecar. Always.
| The Following User Says Thank You to zkv476 For This Useful Post: | Vroomin86 (11-03-2015) |
#6 | |
Kurenai Samurai
Drives: Red and manual
#7 | |
We've installed Motul fluid here quite frequently into the differential/transmission and never had any issues whatsoever. The issue here likely is what everyone else is saying, it sounds more motor related than transmission. |
| The Following User Says Thank You to ModBargains.com For This Useful Post: | Vroomin86 (11-03-2015) |
#8 |
The Fail Boat
Drives: CWP S.B.
Oh man I love Detective story!
| The Following 4 Users Say Thank You to chaoskaze For This Useful Post: |
#9 |
#10 |
Drives: 2013 Brz C38 (bought not built :P)
Let me give it a shot. OP did buy GEAR 300 Motul oil but accidentally put his prune juice in the car and drank the Motul, so his engine died and OP has not responded because well he drank Motul Gear 300 and.... well.... he isn't a diff or a tranny... or wait... maybe he is a tranny who knows these days.
| The Following 2 Users Say Thank You to fumanchu1 For This Useful Post: | go_a_way1 (11-02-2015), soulreapersteve (11-03-2015) |
#11 |
[insert cool phrase here]
Drives: BRZ Premium
My guess he filled the tranny and diff by way of the engine oil fill.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | Vroomin86 (11-03-2015) |
#12 |
| The Following User Says Thank You to humfrz For This Useful Post: | Vroomin86 (11-03-2015) |
#13 | |
Drives: 2015 Fire
You nailed it, best prune juice I ever drank ![]() Well the results are in..... The doctor wrote "P000A" ~ A camshaft position slow response bank 1 ...... I don't have any intake mods other than a drop in filter, no engine mods other than the fluid change, which was done at the dealership and I have no leaks. So is it a total loss or can it be buffed out??
2015 FireStorm FRS
#14 | |
much slow
Drives: 13 Raven FRS, 05 Rio Yellow S2000
Dealership ended up replacing OCV for free and it fixed my problem. Contact your dealership for repair if you are still within warranty |
| The Following User Says Thank You to BAMF86 For This Useful Post: | Kuri (11-04-2015) |
| motul 300 vs motul 300ls about to buy some need help. | NickFRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 03-24-2016 11:51 PM |
| When to check Liquids (oil & coolant) | qbzee007 | AFRICA | 40 | 06-25-2015 03:47 PM |
| Car stalls on highway, force inducted ... No cell!? | RD1428 | Forced Induction | 15 | 05-21-2015 10:51 PM |
| Automatic FR-S randomly stalls when Idling | LzT AngeL | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 12-15-2014 09:31 AM |
| Car almost stalls but clutch is all the way in when stopped | LaertesSon | Engine, Exhaust, Transmission | 11 | 05-13-2014 06:55 PM |
