Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 08-04-2021, 09:26 PM   #1
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Final drive ratios released for US BRZ
So the final specs are back to 4.10 for the MT and 3.9 for the AT...
Looks like I'll MAY never have to leave 3rd on "streets of willow"!
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 08-05-2021, 01:25 AM   #2
fitcious
How does that compare to current Gen?
fitcious is offline   Reply With Quote
Old 08-05-2021, 01:44 AM   #3
Sasquachulator
Pavement Grey
I think the current gen was 4.1 for both AT and MT and in 2017 the MT switched to 4.3 while AT remained 4.1
The Following User Says Thank You to Sasquachulator For This Useful Post:
fitcious (08-05-2021)
Old 08-05-2021, 01:15 PM   #4
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
They've probably gone with 4.1 so when the refresh comes they can give the car a performance boost by moving the ratio back to 4.3.
Sport-Tech is offline   Reply With Quote
The Following 2 Users Say Thank You to Sport-Tech For This Useful Post:
DarkPira7e (05-08-2022), mike2100 (05-08-2022)
Old 08-05-2021, 01:27 PM   #5
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I doubt that. It is way more likely for gas mileage purposes, or something related. The previous gen got a 4.3 update with some minor power mostly due to the complaints of the torque dip and the lack of feel for torque in certain RPM ranges. It did a nice job in covering it up and giving it an improved feel. They stuck to 4.1 for the auto's - again, likely due to gas mileage. For this gen, they reduced the diff for both the MT. They no longer need to have it so high with a nice power bump and a significantly improved torque dip, so it leaves nothing more for people to complain about in that aspect.
Many folks also complained about the high RPM's at highway cruising speeds, which will be less of a problem now with these revised FD ratio's. And as I've already said a couple of times, it will also improve mpg's at highway speeds.
Personally, I loved the 4.3 and will probably miss when I get to drive a gen2 some day. But I do believe it will feel right for the updated power and much quicker acceleration.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
timurrrr (08-05-2021)
Old 08-05-2021, 02:00 PM   #6
Sasquachulator
Pavement Grey
I kind of wonder why 5th and 6th by themselves dont get modified to lower the highway RPMs? Those are usually overdrive gears in nearly every car and not so important when accelerating. These cars do make a healthy amount of torque even in FA20 form. No car is accelerating fast in 6th gear at highway speeds anyways.
Old 08-05-2021, 02:06 PM   #7
Dzmitry
Dzmitry's Avatar
My focus wasn't exactly revolved around highway cruising, but rather that it was another point and complaint from gen1 owners.
In the case of why they don't modify the 6th gear, I am have no clue how the internals of a transmission look, but I would assume that this kind of modification is far more complicated? My guess is you can't just adjust it to have a different ratio, as it will change the gear size and therefore force changes in the transmission internally and maybe even externally? All just guesses, but that is how I see it - and if it is the case, makes A LOT more sense to simply change out the final drive which is an extremely easy modification in comparison.
Old 08-05-2021, 02:30 PM   #8
~el~jefe~
Drives: 2019 MX-5 RF
that's true. gear box changes = millions of dollars of warranty complaints for 2-3 years. Final ratio is so EZ on a RWD car.
Personally, I wish it had a 4.3 plus the new engine. That would be really sick in traffic. burn through gears kind of quick though. it did that already hm
~el~jefe~ is offline   Reply With Quote
Old 08-05-2021, 02:55 PM   #9
ayau
Drives: Some rust bucket
less aggressive FD possibly gives them the ability to get to 60mph in 2nd gear? better 0-60 times.
The Following 2 Users Say Thank You to ayau For This Useful Post:
mike2100 (05-08-2022), ~el~jefe~ (08-07-2021)
Old 08-05-2021, 02:56 PM   #10
fitcious
My 2013 auto FD has been fine lol lol
Old 05-08-2022, 02:46 AM   #11
blackspike
blackspike's Avatar
Drives: Toyota GT86 racing red, Aero
Does anyone know if the GR86 differential is compatible with the first generation? so can I use my old 4.67 differential in the GR86?
And does the speedometer on the GR86 have to be adjusted, or is the speed display not inpactet by the final gear ratio, as it used to be?
blackspike is offline   Reply With Quote
Old 05-08-2022, 08:33 AM   #12
staples323
staples323's Avatar
Drives: '22 GR86
Part numbers are the same so I would assume so.
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD
staples323 is offline   Reply With Quote
The Following User Says Thank You to staples323 For This Useful Post:
blackspike (05-10-2022)
Old 11-11-2022, 03:18 AM   #13
blackspike
blackspike's Avatar
The European version has cooling fins.
It would be interesting to know if there are other differences.
Old 11-11-2022, 10:21 AM   #14
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
For those of us that likely won't at the track... What does that mean for highway rpm in 6th gear at, say, 55mph & 65mph? Considering there are five other gears to choose from, relaxed highway cruising would be nice.
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
tiger1964 is offline   Reply With Quote
Needed: drive line shop in Houston for 4.56 final drive install - good experiences? Joesurf79 Southwest 3 03-10-2017 01:21 AM
Final Gear Ratios FNCrazy Engine, Exhaust, Transmission 28 06-30-2016 01:24 PM
WTB: 4.56 Final Drive jaorocks1 Want-To-Buy Requests 0 11-04-2015 08:36 PM
3.7 Final Drive GsxrMe Engine, Exhaust, Transmission 9 09-28-2015 08:55 AM
Tuning adjustments for different final drive ratios? PantsDants Software Tuning 9 01-29-2014 04:18 PM
