Old 04-02-2019, 04:40 PM   #1
Audio
Drives: 16 FR-S Raven
New Battery/Clutch Friction Point?
Hi All,
I woke up Sunday to a dead Battery in my FR-S. So I got the car jumped and went to Autozone to replace the battery. Of Course I got a Battery with Twice the Power as the oem.. Just Because, "MOORE POWWER".
Now it seems My friction point on my clutch has changed. Have to give it a lot more on the gas to engage the gear. Anyone got any Ideas on this?
Thanks in advance
Audio is offline   Reply With Quote
Old 04-02-2019, 04:43 PM   #2
Originally Posted by Audio View Post
Hi All,
Thanks in advance
The friction point hasn't changed but the engine timing and such has. When the battery is disconnected the ECU loses all of the learned points it has gathered and has to start all over again. It will be back to normal after you drive a while.
Audio (04-02-2019)
Old 04-02-2019, 06:13 PM   #3
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
^ Same thing happens when you tune the car with ECUTEK.
Trueweltall is offline   Reply With Quote
Old 04-03-2019, 12:47 AM   #4
Decep
Drives: 2013 FR-S Series 10
yeah you just got that "dead pedal"
drive it sedately for a hundred miles or so and let the ecu relearn. after that you can beat on it again
ZF clutch in Toyota TS050 - 1.85kg, 115mm friction disc, 1600NM torque rating. mav1178 Other Vehicles & General Automotive Discussions 7 06-29-2016 11:33 AM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 03:04 PM
Thoughts about rebuilding stock clutch. (or, conversation about friction materials) qtwre Engine, Exhaust, Transmission 0 07-09-2014 01:56 PM
Centerforce Dual Friction Clutch and Steel Flywheel Boss Paco Engine, Exhaust, Transmission 4 07-03-2014 08:15 AM
High clutch catching point scionfrs2014 Scion FR-S / Toyota 86 GT86 General Forum 38 12-26-2013 11:39 AM
